Good - Better - Best
Sourdough
Canada
  2. Big Red
I'm sure this topic has been beaten to submission BUT I am wanting to replace my wire rope winch line with a synthetic rope,
on a #3500 winch...I've heard too many stories about maintenance required, so I'm asking the pros., this time..
Appreciate all replies, as to what you have found to be the best for your applications....Thx in advance...
Not sure if this will double post....but...what about the fairlead.....will the roller type, which I have not work and an aluminum
one be needed....can't see the reasoning
Reactions: TxDoc
F
Fyathyrio
242
670
What supposed maintenance? The horrors of occasionally running it through a clean bucket of water? Google yourself some vids of braided synthetic line failure vs steel cable. Not to mention the weight reduction, your shocks will thank you.
Oh, and change from a roller fairlead to a smooth aluminum one.
rickoshea
i prefer wire for what i use my rig for.i read in my owners manual it's not compatible with rope.it's a runva 4500 lb.my Ram powerwagon has rope but i've only used it twice so i can't give a definitive comparison yet.
Sourdough
Canada
  2. Big Red
A user of this line had breakage problem and was told by his Polaris dealer that the line had to be run out and dried when it got wet......Hello...
rickoshea
that's crazy.you can't keep a winch dry unless you keep it in the garage.
Sourdough
Canada
  2. Big Red
I would think that the absense of backlash when breaking when using the synthetic would be the best and safest benefit.
So, I have seen the backlash with nylon rope but they claim that "some" of these ropes are "prestretched".
Would that not eliminate this situation ..???
rickoshea
Roller fairlead is better for plowing. Hawse is better for angled pulls. Synthetic is better all the way around IMO. Can tie a knot in it if it breaks, won't take your head off if it snaps, no frayed wires to cut your hands up.
you don't think synth rope will f you up if it snaps and hits you??i beg to differ.i've seen first hand what a snapped rope can do.that's what a kinetic damper is for.use it or suffer the consequences.
Sourdough
Canada
  2. Big Red
Maybe my original question was not worded clearly enough....This is not my first rodeo with winching and wire rope...haha
But as far as SYNTHETIC line is concerned and the many products on the market....WHAT is the G, B , Best.
109,584
Weeeeeeelllll that's the problem right there!
He had a POO POO!
Question answered ;)
rickoshea
define g/b/best.thicker means you lose distance.most line is safety tested and rated.are you maxing out your rating every time you winch and are you using snatch blocks and pulling from the first roll on the drum all the time? are you winching out of mud or just up rock trails? if not,it makes little difference.next up,soft shackles vs steel
TripleB
TripleB
12,121
103,515
Caryville, Tennessee
$45 will get you two 50ft synthetic lines from Amazon. $25 for a fairlead. Put one on the winch and the other in your recovery bag. Change out your $20+ line once a year If it makes you happy. I have yet to break my synthetic line in over 2 years with alot of winching. I changed it out after one year because it looked rough. The first 1.5 years I had steel cable. Broke it. Would have killed someone if they would have been in the way. Really no debate in the eyes of someone that uses them regularly. My stays wet and muddy. I never pull it out to wash it.
Sourdough
Canada
  2. Big Red
As I mentioned at the onset....I only have a #3500 winch. Original wire rope was 1/4" dia..There is no sense in using a #20,000 line, on a winch of this size..plus a full drum decreases you power immensely, I am looking to find a PRODUCT name for a given dia...whether it be 1/4" or 5/16. There is quite an assortment on Amazon to choose from...I'm asking ..which one G - B - Best..???
