Multi Grandson ready for the next step
Wow! I mean...wow!
What did the 570 do that would make you choose a 500? Must have been traumatic to get you to say that.
570 RZR's will do like 60. And again, 50" machine = not the most stable thing. As @JTW said, you might as well buy a P500 at that point. At least it won't break. A midsize ranger could be an option?
It's really depends on the kid. At 8, I probably would have been fine in a 500, yet I know people who are in their 40's who shouldn't be around sharp objects, let alone mechanized off road things.
I had to follow the old men in front of me about 5 miles up the pass. OH MY GOD!! 2mph!!!! And they were clueless.... get the f*** out of the way! But as I followed I noticed how little travel and GC it had. It was crazy!
43,590
Don't they have more travel than a p500? They are low slung, though. Not much break over.
Yeah... there’s the answer
That's 3 for the Ace. Think we have a winner! @Mudder has one.
Mudder
Mudder
NTC/TAP Transition Member
11,886
90,625
Looks like my grandson is ready for the next step. I has out grown the RZR170's capabilities. What you guys think next machine should be?
Find a good deal on an used ACE, goes anywhere an ATV can and has good roll cage. Although they can do 60 in high range, the low range is good under 25 and for trail riding. 10.25 ground clearance on stock 25s. Go 2017 or newer for better LCD dash display and improved location for voltage regulator. I prefer it over the P500 if not needing 2 person riding, smoother and acceleration power up hills.
Mudder’s Polaris ACE 570
Mudder
Mudder
11,886
90,625
the newer ones also did away with the macpherson strut i think.
That’s correct. Some go dirt cheap as adults move up to a bigger machine. Got mine 60% of value, 53 miles. Would buy it again. Only problem was a freak no start due to a blown fuse on the headlight circuit, twist socket bulb came out on rocky riding and shorted, new fuse and back on trail, taped the bulb socket for extra measure. Just passed 1 year ownership. The ACE is discontinued, replaced by the RS 1.
Reactions: Mudwing and BWAF
Tramguage1
Tramguage1
Texan
7,608
31,549
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
FB IMG 1575235875734 FB IMG 1575236258204
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
is the 170 stock? if so they sell a kit thats easy to put on it to make it taller with larger tires and rear sprocket. my buddies daughter had it on hers she drove it till she was 15 and she was short but not exactly small. you wouldnt believe the difference that kit made
Tramguage1
Tramguage1
Texan
7,608
31,549
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Other than tires its stock. I have plenty more kids in line that can lean on it as it is. I just need a 4wd machine between the 170 and my Talon.
I have been looking at shock mods.
Reactions: CumminsPusher
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
give it a little more umph. but id go with 570 ranger or the old 500 ranger the ace is nice but everyone is talking about 50inch width not realizing how narrow the 170 is. plus on top of that the rangers are slower than the rzrs and ace. also i cant remember if the shift pattern is in line but you could screw a stopper onto the 570 making it have park reverse neutral and low. depending on the model that is some dont have park.
