Multi Grandson ready for the next step
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
Yes, but the 170 is lower and has a way lower center of gravity.
I agree that if the Ace is off the board, a midsized ranger may be the best choice.
i mean the ace is literally a four wheeler with a roll cage. its like a 170 but a ft taller give or take with alot more power. for a kid youd be better off with 2 seater than the ace. hell some of these guys here cant keep the 1000 off it side on flat ground
Lilred500
Lilred500
Keep it on the rubber side
548
1,997
Wv
My vote is still a p5 with 1.5” spacers and 4-3 offset wheels can’t beat the reliability and you can always customize it when they get older.
Tramguage1
Tramguage1
Texan
7,608
31,549
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I'm liking a p500 also
But I'm checking around and see what's available. If I get another machine I will be up to 5 machines !!!!!!!
That’s why I’d keep as many as possible Japanese. Maintenance will be cheaper with more longevity and resale. For awhile we were up to 9 every weekend and the only stuff I could running were a few Yami’s and the Honda’s. Putting any decent mileage on the other stuff was impossible without constant upkeep .
Reactions: Tramguage1
43,589
Yeah, it is. I'd bet it's also more stable than a 500. I'd bet many quads are.
If we're going to widen out a 500 with wheels and spacers, then in many ways it's ideal, but I don't like the thoughts of a young, relatively inexperienced Pilot in a dead stock version crossing ruts or on sidehills.
Tramguage1
Tramguage1
Texan
7,608
31,549
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Liking the Yamis also
Reactions: CumminsPusher
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
i dont know about that. the ace i seen riding around sabine atv park seemed to always be on his side. a stock 570 ranger or 500 pinny are pretty stable compared to the ace. little heavier and wider too.
Reactions: DG Rider
43,589
Then I would avoid the ACE for sure...
There is NO WAY the Ace is more tippy then stock 500.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
570 ace that is. unless your putting an 8 yr old in the 900. that is
Reactions: DG Rider
Landman
Landman
The Great Bearded One
594
2,410
Central Arkansas
stock vs stock on the same trail i seen ace on his side and 500 go right on through it
Unless it was the same driver running it in each machine, that's not a fair comparison. I mean, the driver of the ace could've been someone like @Smitty335, @JTW, or @Kilo427... if you'd reverse the drivers, the ace may have made it up just fine and the 500 would've been on it's side!
It’s true...
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
if i hadnt seen it with my own eyes id say the same. but it was left leaning trail and everyone was in the same rut. going 5 ish mph.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
New SxS are tested and rated by government mandate.
Quick internet search:
ACE 900xc tip over angle (green tag) = 42 degrees
P500 tip over angle (green tag) = 33.5 degrees
@JTW results may vary.:rolleyes:
whats the 570?
Reactions: DG Rider
Tramguage1
Tramguage1
Texan
7,608
31,549
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
When is Honda jumping in the youth sxs market?
Tramguage1
Tramguage1
Texan
7,608
31,549
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
i thought they did with the 500. but then all the adults started using them. id like to see them come out with 250 4wd sxs kinda like the rzr170
I'm right there with ya!!!
