I'm extremely happy with mine, you can't beat the price. Also front panel programmable, plus the programming cable for faster setup is about 15 bucks off ebay, overall the sound quality has been great. The only downside I've seen so far, is they don't suppress some of the end of hail squelch that the motorola's put out when I was using one on-site with a client last year. Besides that SOLID. You could also setup a couple of the reasonably priced Yaesu base stations in a repeater configuration, that way you can get better handheld coverage station to station by setting up a nice big omni antenna at home, and then relaying through it to speak to someone else at the far side of the property outside the range of the handhelds. Lots of fun stuff you can do for well under 1000, even an interconnect into a landline if you so chose, however to do that you'd probably want your own VHF frequency instead of using the ham bands.
