P700 Hard shifting between D-N-R
Tramguage1
Tramguage1
Texan
7,495
30,712
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Does anyone else have a problem shifting there 700? It seems to me it's a little tough to shift in and out of gear.I thought it was because it was new so didn't ready worry about it. Now it has over 100 miles and still not a smooth easy. Making sure it's not moving, on a tilt and emergency brake set or not . Has anyone adjusted the linkage on theres?
Thanks,Mike
Reactions: AndrewsSeed
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Thanks,Mike
Check out this thread-
gear selection lever | The Honda Side by Side Club!
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Spraying lube seems to help a bit. Open the hood and look up underneath toward the dash. You wil see two linkages, one for the gear shift (D,N,R) and the other for drive mode (2wd, 4wd, 4wDL). Simply spray lube on any moving parts on the linkage. I can try to get a picture later today if you need one
Reactions: HappyHonda
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
I too started a thread about this. Since then I've noticed: You can crank the vehicle in gear if your foot is on the brake. After I do this: it is REALLY difficult to shift. Mine shifts a little more freely if I crank it in neutral.
swsebek
swsebek
2,854
5,835
pa
It will loosen up over time,alot of other owners experienced this,including myself.about 500miles
Farmer
Farmer
2,973
17,158
Southern MO
It shifts a lot better while it is rolling/coasting to a stop. I know I know, it's bad to do that because you could slip and land in opposite gear but it's a habit that formed from things feeling like they were going to break. It feels like the gears inside just don't want to disengage when it's not rolling.
Reactions: swsebek
roadturtle59
roadturtle59
10
5
So does spraying silicon on it work? If so, can you tell me exactly where it needs sprayed? I've had my 700 for over 2 years now and it has always been hard to shift.
Yes it fixed mine. Spray the linkage heavily
bigc
bigc
432
127
i have found that changing engine oil to hp4s makes a huge difference
dale5740
dale5740
886
417
mt airy md
Thanks,Mike
make sure your idle is set properly that can def cause hard shifting!!
