P500 Hard start cold
25yrds
150
370
It's the seat belt light, you must be latching in right away.
Yeah, hehehe, I plugged the passenger side into to driver side. Don't by any means advocate this but it's what I needed to do
25yrds
150
370
Yep, I've seen it. For now this will work
RumpRocket
189
295
USA
Are you stepping on the brake paddle while cranking it?
Mudder
Mudder
NTC/TAP Transition Member
11,885
90,608
Only time mine doesn’t start right up is if I’m to impatient to let the fuel pump finish. No trouble codes displayed? Frustrating. Under warranty, then call dealer? Following and thinking...
212,770
My battery is 3 years old and still starts fine, if I let the fuel pump get going first.
Reactions: Mudder
Lilred500
Lilred500
Keep it on the rubber side
548
1,997
Wv
Mines an 18 with 300 some odd miles on it and it does the same if I don’t let the fuel pump cycle all the way. Long as I let it do it’s thing it hits right off the bat and tires right up.
Reactions: Mudder
25yrds
150
370
Believe me, I'm letting fuel pump pump up. Even cycle it 3 or 4 times until I hear it stop. I'm an ASE certified (30 yrs) auto and heavy truck mechanic. I
Reactions: Mudder
Splorin
320
904
Maine
2015, original battery, 10 degree weather this weekend. Mine would crank a little longer before catching but I wasn't surprised due to conditions. Inspect plug because it could be fouled from short runs at dealer if it was moved around every day but never actually run any length of time. New plug, full tank, excuse for a long ride. Don't forget what 'new' stands for, never ever worked.
T
Tstover
141
398
Central PA
My .02 on this is a tight valve, been there, done that with a 4wheeler before, same exact issue.
Reactions: 25yrds
25yrds
150
370
Ok. This evening I tried to start it. Cycled key on/off 4 times, 5 seconds between. Heard pump go every time. Cranked for 6 seconds and didn't fire a lick. Stopped, tried again, about 3 seconds in she "coughed" through intake and fired almost immediately and runs flawlessly, restarts quickly every time now, even though I shut it off second it started. 60 degrees. Sat all weekend without running. Tomorrow I'm gonna put a jump box on battery first thing, as I just don't think she's cranking as fast as she should, and see what happens.
212,770
It's a P5! HA! just kidding, what's the age of your battery, you have some pretty cold winters in Idaho. The battery in our P1 is a little over 3 years old and I'm thinking about replacing it with an Odyssey like my secondary battery. The original is getting a little slow when it's cold.
Reactions: 25yrds
Mudder
Mudder
11,885
90,608
Many posts on how sensitive these engines are to even the slightest compromise of battery strength. Finally replaced mine recently after going down rabbit holes, cleaning connections, etc. Showed good voltage, but weak on actual cranking amps.
Reactions: 25yrds and Splorin
25yrds
150
370
My suspicions exactly
