Harness bar
WagginTail
WagginTail
1,646
6,047
SC
Tramguage1
Tramguage1
Texan
7,594
31,395
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I see on FB they are making another run of the harness bars Screenshot 20220312 222305 Facebook
Spencer357
Spencer357
56
298
53
South Carolina
We would maybe like one as well, depending on price.
250 and after shipping it was 302. Sounds a little high but hell what isn’t right now. Amazon has some nice harness around 200 for a set. I rolled my pioneer 3 times all at once and have a hospital bill that is ALOT more than this setup cost. I truly believe if I would have had the harness I would have walked away un hurt
Tramguage1
Tramguage1
Texan
7,594
31,395
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
There are a lot of different harnesses out there.
I personally us the Pro Armor 3" 5 point harnesses in both my P1k and Talon 2X.
Most of the lap belt anchor buckels holes will need to be either enlarged or new 7/16-20 bolts purchased to attach at the factory location.
116,566
You can mount your harnesses another way witch will cost you nearly nothing that I did back in the old days. Actually got the Idea from @JACKAL original build. It works very well. I only changed to something different cuz later I altered the machine and that was no longer going to work.
heres a quick link to my build and go to post #78 to see the finished product
Spencer357
Spencer357
56
298
53
South Carolina
Can you post a picture of how you mounted the 5 point in your pioneer? What did you mount the strap between legs too?
Tramguage1
Tramguage1
Texan
7,594
31,395
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Lift the seat bottom and drilled a hole in the square tubing frame. The through bolted the strap buckle. I added this strap to hold the waist belt in position when you pull the shoulder belts tight.
I will go out in a few and snap a 📸
Spencer357
Spencer357
56
298
53
South Carolina
Have any of y’all been to RRB? If so would a stock P1k make it up to what they call top of the world? Me and my wife are wanting to go but just want to make sure I can even make it up there
Neohio
Neohio
Beast of the East
21,733
93,023
Painesville Ohio
Yes, a bone stock will do it. @JACKAL is a guide in the area. He can tell you which trails to avoid.
