Talon Has anybody tried Maxis carnivore 32x10x15 on stock wheels
Christepher
82
104
PE Canada
I'm thinking of pulling the trigger on a set of carnivores.. but notice that they say the compound is great for rocks/dessert driving.. does this mean they aren't going to be any good on snow/ice? Does anyone have feedback for that? I live in eastern canada and we do get a lot of winter driving in.
bjniceguy
322
431
Iowa
for what it is worth, I have the 30" Carnivores on my YXZ. At 450 miles fronts show no wear, but rear have some (not extreem but show more than my Liberties did at 600 miles). I plan to just rotate front / rear. I had them at Moab in rocks & on a big ride across Utah by Hurricane with lots of loose rock. I generally love the tires as far as handling, quite, and smoothness on roads. They clean out light mud a lot quicker than the liberties. The Liberties seem to throw mud forever after going through a light muddy area (not deep mud, I avoid it)
Reactions: IDIOT
Choped5er
Choped5er
182
279
Union
As promised, here are the 32” Carnivores on stock wheels. I’ve only ran them down the road and back for about a mile so I can’t provide any valuable trail feedback yet.
I can definitely say I immediately noticed there’s more tire to get turning. For my riding style it probably won’t be any kind of an issue. However, if you’re a fast-paced rider or racer and find your self rapidly accelerating frequently to get up to speed, then you probably won’t like these tires without a turbo.
I did notice, though, that they seem to have relieved some of the jerky throttle response so that could be a silver lining with the added size and weight.
I don’t see any clearance issues and don’t think they’ll rub at all on the R model. I can’t speak to the X model. My width is now exactly 70" front and rear.
View attachment 135756 View attachment 135757 View attachment 135758 View attachment 135759 View attachment 135760 View attachment 135761
Who makes those rock sliders? And do they come out as wide as the tire on the rear?
hondabob
1,161
4,537
Prescott Valley, AZ
My buddy installed 32's and said the top speed was 62 mph at Moab. I installed 30 inch Terrabites. At 5,000 feet elevation my top speed is 73 mph and it takes awhile to get there. The stock tires hit the rev limiter at 75 mph. I need a good top speed and the 30's are working great. Most of my high speed cruising is 40 to 55. I run a lot of 4th and 5th in the sand washes. If your going to install the turbo they have a flash for 28's, 30's, and 32's.
SmokeyMike
20
30
Central Florida
Jason I would like to put 32x10x15 pro armour on my stock talon 1000x wheels, I know the 1000R is a wider machine do you know if these will fit on my X?
jasond
jasond
220
350
Indiana
I can't speak to what tire sizes will fit the X model without rubbing. I don't want to steer you the wrong way so I'll let someone with an X chime in on this.
K
KenThompson
265
603
Mulino
Has anybody tried Maxis carnivore or any brand 32x10x15 on stock wheels, i’ve seen or 9 inch wide will fit I’m concerned about 10 inch wide with the shock mount I’ve already got them ordered I wonder if I need spacers
Just put 30” terrabites on 5+2 wheels. I think 32’s would rub the front fenders when turned and hit the rear shock mount. Not sure if the power steering would like 32’s or not.
Jefferson87
Jefferson87
258
275
Northern California
I've got 100 or so miles on 32 carnivores on a stock x4. I've had the front rub slightly twice, once I was sliding around a corner in the snow at speed. The rears popped out of the ruts and tried to come around, so I was full crank and hit a little bump. The other time was coming down hill and crossing a ditch while having to crank hard again. All the weight was on that tire.
I did over heat my power steering once, we played in the snow, so dropped to ~5 lbs and then drove a few miles home on a very windy road. But before that, I've done entire rides in the snow at 2 lbs with no issues. Just the mix of pavement and low pressure is what it didn't like.
Code54
Code54
583
626
Hurricane West Virginia
Any additional feedback on the 32x10x15 Maxxis Carnivores on an X?
Reactions: Isaiah
Sawpilot
Sawpilot
57
151
West Virginia
barnwoodbuilds.com
I have a new set that are not inflated yet are 30 inches I think the ones on my machine are 31 inflated. Completely different machine with these tires, put it in low range keep the beer cold it is a monster 3500 miles NO belt anxiety
922265AC 944F 4382 9961 67B9369BEDB9 6AE304A0 01BD 457D 840D 84D6F265EDF4 62F50284 35A5 4E05 BCA7 CE5B858959B7
Isaiah
Isaiah
2,191
6,964
Altamont TN
Test - Grid
