P500 HAVE NO PIC OF THIS...NOR DO I WANT ONE..
rocmar
rocmar
4,741
5,776
4 CORNERS
Wasn't gonna bring this up...but I thought
& decided to share..shameful but could keep
...it happening to others...while coming home
From a dawn drive..decided to hit my light bar.
road was bumpy...not knowing I hit the out..on my
winch...dragging tail..for about 100 or so feet..
now looking for covered switch...glad I wasn't pulling
..into a group of riders...
Thought I'd share...
178,781
Yikes! Did it screw up your cable? That could've been horrible if it had grabbed something on the trail just right. I was going to ask if it was 4:21 pm but you said a dawn drive. :D
Reactions: rocmar
rocmar
rocmar
4,741
5,776
4 CORNERS
HaHa...not a 420...deal...
Yeah..could of wrapped around rear wheel...
no..just pulled in..dragging
Tail..lookin like a DumbAss...
never dawned on me..that it could happen. ..
Pretty crazy.....
green lit-up...cover..will look
....tits..huh
Reactions: trigger
rocmar
rocmar
4,741
5,776
4 CORNERS
95% of 420..
done at home...
but there's camping...
& a concert...every once
..in awhile.
No one to blame..but me
rocmar
rocmar
4,741
5,776
4 CORNERS
The switch... isn't it temporarily off/on?
To get it out long enough to drag, you'd have to hold it down?
Only used it once..
apparently not..
installed by Honda...
default switch..
just checked...push off or on...
stays there...till ya stop it..
which is in the middle
rocmar
rocmar
4,741
5,776
4 CORNERS
Yeah...middles off...
up...is out....down is...in..
rocmar
rocmar
4,741
5,776
4 CORNERS
Can't be..off or on...
it's a winch...
has in or ...out
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Yes...I do..
So you've done it...or know
of those that did?
Yes for right now I just have a simple lighted toggle with a cover in line with the winch rocker. Toggle on power to rocker.
Reactions: rocmar
rocmar
rocmar
4,741
5,776
4 CORNERS
Mines not lit...
solid black...cheesy..
looking for something..
same size..with cover...
which I guess that's why they
...have a cover..if I knew..wouldn't of
mounted next to...other switch
rocmar
rocmar
4,741
5,776
4 CORNERS
So...I'm not a real good..elec guy..learn as I go..
only smoked..2 L.E.D. lights..
so lighted toggle...powers rocker..
to use winch?
Reactions: GlockMeister
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
to use winch?
Yes. Key on power runs through toggle to winch rocker on mine
Reactions: rocmar
rocmar
rocmar
4,741
5,776
4 CORNERS
61RQvMzghCL SY355
kool...gonna go with this..
loading up the cart..haha
thanks..bro
rocmar
rocmar
4,741
5,776
4 CORNERS
You were trying to describe...bump
switch..which means..goes out...or brings in..
..as you bump the switch....correct.
mine don't do that..but my neighbors does...
only used once..2 half yrs ago..
so can't say if it was always that way...
or now it is..
just sayin
They are called momentary switches. I use one for my winch too. Just for safety though I use a winch power switch also. So I flip a power switch and then use the in/out switch. I guess the covered switch saves space though
CP: I've been saying that since that jack wagon was picking Legos from his turds:)
Reactions: trigger and rocmar
