Headlight upgrade?
SWB
SWB
1,972
6,934
South Central Arkansas
Those who have upgraded their headlights on Pioneer 700. What is best bang for buck on headlights? How long have you had them installed. Some part numbers would help in advance.
Thanks in advance.
SWB
Reactions: TxDoc
Thorney
Thorney
101
382
Minnesota / Wisconsin
Very bright.
Screenshot 20210528 211038
Reactions: SWB and Mudwing
7,143
27,176
Reactions: TxDoc
03mossy
03mossy
275
1,080
MN
  2. Other Brand
+1 what Thorney recommend!
grabbe123
grabbe123
155
Paris, IL
Has anyone replaced just the bulbs in the headlight? Wanting a brighter bulb without spending $225 on the actual assembly...
7,143
27,176
My problem with just bulb replacements was the reflectors are designed for a certain bulb. The resulting light output is scattered and not focused corectly.
Rayger143
Rayger143
2,741
23,737
Winfield, BC Canada
If I was you spend your money on a decent light bar setup. PBR products has cool brackets so you can mount a 50-54 inch bar. Lots of switches and wire harness at the club store to make install easy. Amazon has some pretty cheap light bars. After all you just wanna see at night right?
Thorney
Thorney
101
382
The bulb replacement isn't a substitute for a light bar or other add on. It is just a cheap way to improve upon the dim, yellow halogen lights that come from the factory on the 700's. Well worth the $35 bucks. Definite improvement for a road ride home in the dark. If you are running trails at night, by all means, get supplemental lighting. For my use (mainly ice fishing and hunting) the bulb replacement is a perfect upgrade.
Teebow
Teebow
281
1,185
Kentucky
I have light bar. Just want headlights to be brighter than night light that you plug into wall. Lol
I just purchased a light pod kit. 2 4in pods mounting brackets and wiring harness 45$(amazon) mounted them on the side roll bars and it’s like I don’t even have to turn the headlights on.
Reactions: SWB and Rayger143
