Heat Control - Thermal Barrier Coating
G
gone_riding2
0
US
Has anyone tried getting their exhaust coated to reduce cabin heat? Did you notice any difference?
These places claim decent to significant heat radiation temperature reduction by keeping it in the tube and going out the exhaust usually with a ceramic type coating.
PaulF
PaulF
1,462
4,817
Take any "claim" that anybody makes about their products with a HUGE grain of salt. Mostly sales talk. Did they stop claiming all the power advantages like they used to in the past? Now they are peddling "heat radiation reduction"? What next, noise reduction too???
For comparison, I wrapped my exhaust at one point (same basic concept) and it helped a little (very little to be honest). Although there is heat from the rear, the main heat source that you need to control is from the front, not the back. Short of relocating the radiator to the rear, the DEI Heat Kit and the Shifter Boot mod are the best options for the money in my opinion. And the DEI kit comes with a rear heat shield for behind the passenger seat. The shifter boot mod is the best $20 and 1 hour you can spend to alleviate heat intrusion.
DRKnight
136
269
Yuma, AZ
I have used the ceramic coating on the exhaust of pipe of a ATV I had that did help.
My wife would complain of the heat from the plastic side next to the exhaust pipe on her leg and after coating she no longer complained.
I have a riding partner that had a problem on his 800 RZR that the pipe was melting the plastic behind the seat and had the pipe ceramic coated and it stopped the problem.
I can notice a large difference on my exhaust headers on the street rod from coated and uncoated..
So I can see a very good improvement in felt radiant heat...DRK
Reactions: Rayger143
SLOWPOKE693
SLOWPOKE693
1,975
7,697
Somewhere in Texas
DEI header wrap works for me. 🤷‍♂️
20210823 221529
HROY60
HROY60
10
24
wyoming
Finally rode a decent ride today (95 miles). I have to say the DEI kit made a difference for me. Behind the passenger was a 95% improvement, before the kit I could barely put my hand back there. As far as the front part of the kit, I feel it helped out 85% - 90% of the heat coming through the cracks of the fire wall. I will say you that you will still have to apply the shift boot mod for the best result. Hope this helps.
Deathcure
5
9
WV
I tried painting and wrap on mine with the hmf full exhaust. Paint burnt off in 1 short ride header tape lasted 2 weeks
Get you a 4 seater and the heat problem is solved, especially if you boot the shift gate as @TerryH documents in a shop video….
Reactions: TerryH
SLOWPOKE693
SLOWPOKE693
1,975
7,697
Somewhere in Texas
I wrapped my HMF exhaust with DEI header wrap at the beginning of the race season and have had zero problems with it. I didn't use the paint they recommended either. Pulled it off last month to add 02 bungs and then rewrapped it with fresh stuff. If I didn't have to do the bungs the original stuff would still be there. I also don't aim the power washer directly at it and blow holes in the wrap.... Maybe that has something to do with it lasting.
20210823 221529
