Heat in cab
N
Ned
241
183
West Kentucky
The heat gets worse the longer you ride. The longer you ride the trails the rubber shield is all that keeps the heat off your back. help Honda lets fix this problem. This will be a bigger problem when someone try to put some insulation under the seat and it cause a fire! OR it melts the rubber on your back.
I also placed a bilge blower under the seat along with some under seat insulation almost completely fixed the hot seat issue.
Rocky
Dothan, AL
Are you running a full cab in the summer? That is the only way I can see you having a real heat problem. I live in North Louisiana with similar temps as you, and me, the wife, and kids just went for a 6 hour ride (55 miles) last Saturday and it never got more than warm. No complaints from anybody except if we went through water deep enough to create steam from the engine/exhaust - and that was very temporary. We even have a full skid plate from Factory UTV. We are not running a windshield or roof. Our average speed is about 9 miles/hour, so there is some airflow. There are times we are running slower, and times we are running much faster.
Give us more info..........
IMG 20160623 223440589
I have the Honda OEM hard top and a wind screen only.
Stauvo
Stauvo
633
910
Minnesota
Today we did some woods trail riding and the temp was 85. My wife whome is always cold made the statement about how warm it was getting in the cab. I have full EMP window, soft top. I agreed it was getting hotter the more we rode. I may need a bug buster and heat shield sooner rather than later. I can sure understand you southern members with added humidity.
Reactions: CumminsPusher
322,773
Hey @Stauvo I'm pushing then to do a group rate as others here have. Call and talk to Mike and voice your opinion on the same thing. Btw they sent me a new one after I screwed up mine. They are great
Reactions: Stauvo
Stauvo
Stauvo
633
910
Minnesota
Cool! Thanks CP. I will try to call tomorrow or Monday if closed.
Z
Zeke1000
Illinois
I just purchased a 2016 Hond 1000 3 SXS and battling cabin heat issues. After 15 minutes of riding the plastic behind the seat is too hot to touch. I'm also worried about the amount of heat on the fuel tank! I insulated the panel on the top side but now he heat rises up behind the seat back. Wife and kids are refusing to ride. Help!
pgiannetto65
pgiannetto65
97
155
Remove engine cover and problem solved
C1429be9caeff9b01ccb5a06d3f6e24c
Reactions: elkguide
pgiannetto65
pgiannetto65
97
155
Remove this
Db22273fbecf7b05d35651eda618de5d
Reactions: elkguide
