Ok long story short I was checking my air filter this evening and had a bolt that was stripped , I had to remove the top part of my seat and get the bolt out, after I was done and put it back together I backed it out of shop and it started idling high and wouldn't shift into High or Low range , turned bike off and shifted into high and drove it around yard and still idling high and wont' shift into Low or anything without turning it off, cant' imagine anything I could have done will checking air filter to cause this, only thing is its cold outside.
