HELP!!!!
Have you tried rolling the machine back and forth?? Kinda sounds like when it's between gears. Might be worth a shot
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Kinda sounds like you're missing a ground or have a short.
Reactions: Plumber32 and JTW
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Odds are it's something simple. Did you say you unhooked everything you added and still no display?
xltman
xltman
188
369
US
Yup, unhooked battery, then no start.
Sent from my XT1585 using Tapatalk
xltman
xltman
188
369
US
I tried the between gears thing, no luck. I really think I've got it down to the keyed ignition. I only get continuity across two posts. Looking for a good wiring diagram that doesn't blur out when I zoom in.
Reactions: JTW
Tramguage1
Tramguage1
Texan
7,496
30,712
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Sent you a PM
Tramguage1
Tramguage1
Texan
7,496
30,712
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
the one I sent you also?
xltman
xltman
188
369
US
Maybe someone has worked with the ignition switch before and can either verify or tell me I'm dead wrong. From what I can tell the two large spades are both 12v power. One set is for the starter and the accessories and headlights, the other is for the fuel pump, ignition. When I bench test the switch I only get continuity across the incoming 12v and the center bottom spade. This leads me to believe I have a bad ignition switch.
Tramguage1
Tramguage1
Texan
7,496
30,712
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
that sounds correct. the first positon should make fuses D and E hot, (ACC.)
the next should be start position and C and B fuses hot.
can you get a picture of the back of the switch?
Reactions: Cuoutdoors
Tramguage1
Tramguage1
Texan
7,496
30,712
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
bottom left side of drawing show the connections on the ignition switch
xltman
xltman
188
369
US
Ok, so after retesting the ignition switch, all seems to be working there. Now what? 13265820ad789984e3bbf29a4bb4156e882eb45233fec1d9a0a63f46d642ca9d
Tramguage1
Tramguage1
Texan
7,496
30,712
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
When you sid you read continuity at the fuses, did you remove each one from the fusebox?
Are any relays clicking when you turn key to on? (1st position)
xltman
xltman
188
369
US
No relays clicking. I pulled and checked each fuse. Next I will test voltage at each fuse.
Tramguage1
Tramguage1
Texan
7,496
30,712
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Ok
if you download the wiring diagram does it help when you expand it?
If you have a test light check which fuses are hot in each position of the key.
swsebek
swsebek
2,854
5,835
pa
Did you try pressing the brake then turning the Ignition at same time.
xltman
xltman
188
369
US
Ok
No, when I zoom in it won't focus, poor resolution. I am using a fluke meter, not see much voltage at the fuses.
Tramguage1
Tramguage1
Texan
7,496
30,712
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Can you get to the plug that goes to the key switch with you meter? There should be 2 wires that are hot all the time.
Tramguage1
Tramguage1
Texan
7,496
30,712
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I think they are solid red
