Honda cabin comfort installation
Bones
199
203
Bourbon Mo.
Hello All,
I had the cabin comfort and clutch update done by our local Honda shop recently. The heat issue really didn't improve as far as I can tell. Is this all they do for the heat fix?
IMG 2736 IMG 2737
Paulswa1
Paulswa1
14
Strawberry AZ
I had the mod
Hello All,
I Had the mod done too and it helped some but I put in some heat shield pad behind the plastic panel between the seat bottom and seat top and cut a piece of carpet for the same panel that fits between the seats on the inside and that helped more. I also wrapped the exhaust with exhaust heat tape and that helped as well.
E
Ericthered
Eric The Red
271
522
Sparks, NV
Yup. That's it. A piece of rubber with numerous holes, but not where you need them for servicing the sub-transmission. All I can say is go on-line on eBay and get a 4 inch bilge fan. Mount it to left side pulling heat away from the exhaust and rear of seat. When we hit 80 degrees we felt some discomfort and turned on fan for just a few minutes. Cooled it down till we were crawling again, then put it back on. Easy install, and cheap. If you spend $35 you spent too much. That includes fan, wire, switch and strap to hold fan.
jay_man81
jay_man81
356
1,158
Central Pa
www.facebook.com
Yep, that’s all it is. It does a decent job at keeping steam from coming up into the front if you get in water but at the cost of channeling it all right in to your rear passengers face if anyone is back there...lol.
I had mine install last fall so couldn’t really tell how it work till now but I will say this. Surprising it does help keep heat from being transferred into the seat and into the back of the middle passenger. But as for raident heat it doesn’t do that awful much.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Yea that's all it is. Adding a fan under the seat is the best solution and does the trick. You can even add a vent to blow warm air into the cab in winter if that's something you need.
No machines are perfect. These machines need the clutch update and a fan. You're half way there. They are a fantastic machine afterward.
suebell
suebell
19
25
NC
@Hondasxs what do you think of the cooling fan?
Ragnar406
Ragnar406
The Great Bald One
4,449
17,027
Bella Vista, AR
The cabin comfort along with the heat shield has really helped but if you have a full windshield you are going to feel some heat. I recently went from the Honda windshield to the Super ATV flip windshield. Yesterday went riding in high 90* weather and never noticed heat except for the few times I would close my windshield .... I noticed it get warmer almost immediately.
quickfish
quickfish
36
46
Kent, WA
Or go to eBay and get the reversible fan and blow the heat out in the summer and blow the heat in the winter
Farmerjohn
Farmerjohn
92
167
Upper Peninsula of Michigan
I had this exact question today. I put in my vent kit and had the seat off...
Dissapointed to say the least!
Anybody have a link to the reversible fans, or something I can purchse to solve once and for all.
Thanks!
