P1000 Honda Dome Light Wiring
HondaTech
Normally the Honda Dome Light has to be turned on and off with the button on the Dome Light.
Even if you wired it to a switch, the power resets and the switch on the light must still be pressed to turn it on.
Well if you cut the 2 pin plug off (fuse box end) there is another wire inside (i believe its yellow). If you use this wire instead of the red one with a switch, you can use your switch to turn the light off and on instead of the button on the light. Leave the red wire loose and not powered.
I used this to make the dome light and floorboard lights come on together with 1 switch. The button on the light will still work separately as well, if needed.
I found this out awhile ago while installing the Honda dome light in a fellow members's Pioneer and forgot to post it.
ODAMO
ODAMO
1,283
3,450
Ohio
You've probably forgotten more than most people know. 🤔
Reactions: Rayger143
Scrappapotamus
The Scrappapotamus
738
3,919
Midway KY
  3. Talon X
  4. Talon R
  5. Talon R LV
HondaTech wired up my Pioneer with a dome light, front floor light and rear bed lights, all LED and switched. Very meticulous install and extremely functional. I'm not into scabbing a bunch of amazon crap together. Lot's of light and very integrated within the machine. He also changed all my switches to the illuminated ones. Before, I fumbled around looking for switches or items in the dark. Now it's like being in my automobile or truck. Thankfully I reside in somewhat close proximity to Honda of Fairfield where HondaTech turns wrenches.
Neohio
Neohio
Beast of the East
14,573
73,611
Painesville Ohio
You should add that as a google review for the dealership.
