if you have the Honda OEM Lightbar you well want to read this and make the fix before it falls off.
the set screw is way too short to withstand any big G Force.
example: I was running the desert outside of Barstow, the area has a lot of whoops, big and steep ones that the 2 wheeler leave. I was running at 40 mph through them when the light popped off. in the pictures you will see the OEM screw only catches 2 to 3 threads and will pull out as it just does not catch enough threads to hold,
The replacement screw you will need, 5M X 20M FHCS.
The new screw will be 1/16th too long. grind it down and file the threads and screw it in by hand. job is done
