Honda OEM Lightbar fix
Outdoorplay
Outdoorplay
7
OC Ca
if you have the Honda OEM Lightbar you well want to read this and make the fix before it falls off.
the set screw is way too short to withstand any big G Force.
example: I was running the desert outside of Barstow, the area has a lot of whoops, big and steep ones that the 2 wheeler leave. I was running at 40 mph through them when the light popped off. in the pictures you will see the OEM screw only catches 2 to 3 threads and will pull out as it just does not catch enough threads to hold,
The replacement screw you will need, 5M X 20M FHCS.
The new screw will be 1/16th too long. grind it down and file the threads and screw it in by hand. job is done
KIMG0088 KIMG0089 KIMG0092 KIMG0098 KIMG0118 KIMG0119
Thats odd, the installation instructions don't list any 5mm bolts for the 40 inch light bar. Everything is 6mm or larger?
Outdoorplay
Outdoorplay
7
OC Ca
well take your screw out and take it to the hardware store and match it up. or if you have a mic,
Honda just replaced my Lightbar for free as the OEM bolt is to short witch you can easily see by looking at the pic's you can see they only catch at the most 3 threads but looks more like 2
