Honda Pioneer 500 on tracks?
63,554
Re: Tracks
Here you go... The First P5 on tracks!
Don't have any info on it.. Yet...
All I know is I would love to take it for a spin.
2015 P500 TRAC PIC 1 2015 P500 TRAC PIC 2
L
loys72
9
Where are you found that ? I d''ike to know more info.....
I
iam_canadian22
20
23
Moved it around with just the backs, its noticeably lower but not as noticeable as when they were on my outlander if that makes any sense, might be because the p5 has much smaller tires to begin with, they say 30ish % reduction
Reactions: Dp5hunter
I
iam_canadian22
20
23
Well finally got it all done, took a while as i had broke an anti-rotation arm last year when i had them on my atv so had to fix that up
Bab1b78598457cfba28e48ab645230f6
5c565556b9359950ab4b2b9cfd48193b
solrus
solrus
1,629
2,511
Montana
What top speed can you go? Is camoplast is the only option? Will mattracks be too heavy for P500?
I
iam_canadian22
20
23
Havent checked top speed yet, camoplast and kimpex are the only 2 ive seen, these are older kimpex wide tracks, they had no mount kit for the p5 for them so i modified what i had
IdahoPioneer
IdahoPioneer
244
600
Emmett, Idaho
The Tatou 4s seems to fit fine. My parents bought this set for their rhino about 6 or 8 years ago. Looks like a handy person could fab up some brackets to work for the stabilizers. I drove around just a bit without the brackets. 5th gear feels a little under powered but other than that it drives great.
IMG 17501
265,454
Looks like a micro size snowcat definitely cool. I see where RMATV has them to fit the P500 brackets n all.
ofrcboy
ofrcboy
501
572
Oregon
How cool are those with tracks. I could see getting way off the beaten trail with those but if you break something it would be spring before you could retrive the machine. Would love to try some day, thanks for sharing.
solrus
solrus
1,629
2,511
Montana
Since there is no front diff lock, would you consider all four track system or just front skis and tracks on the back?
Less weight? easy to install ? Any experience with Ski cobra brand?
IdahoPioneer
IdahoPioneer
244
600
Emmett, Idaho
For my situation I could never use skis in the front (if I could I would be using snowmobiles). The non plowed road to my cabin gains almost 2000 ft elevation. Often times it is muddy/rocky at the bottom and I'm into 2 ft of snow before reaching the cabin. This requires a fully tracked vehicle.
That said, even without diff lock 4 tracks will far outperform 2 based on what I've seen.
