Honda switch plate and lights
I finally got around to wiring up my lights today. First off, I purchased a pioneer with the OEM switch plate and fuse box. Having this made the installation of the lights super easy. I took a few pics for anyone that may be interested.
Here is the switch plate with some aftermarket switches installed. Best part of all, the wiring harness was prewired and plugged in directly to the switches.
0a79097b3344180e35750a6190458aad
Here is the back side of the switch plate.
80455251e474348bbd97df29a113e6bf
Here is the fuse box cover.
6c01b5099962b89c276b25ad1c7aedb5
Here is the inside of the fuse box and some wiring connectors that I just happened to have on hand. We use the same thing at work.
Ba509cb68320eec5288ee1cf5c11247e
Here is the connector on the light bar wire. It just plugs directly into the connection inside the box.
2115897acc038ca2868dc772d7fa9262
Here is a pic of all three accessories plugged in.
09e8bd2c104cc80d255d6bf8a07aea10
Reactions: bobbyhill
Here is the finished products.
D935baad0623429c0c6ba09a9a5df65c
441bcc3018a3b9bfcc15ca67231d1b9d
5f19574277417b5d7b3de7f1eb8bf319
Beacheagle70
Beacheagle70
Very nice job, I am going to move the factory panel to the center of the dash where the information placque is located. I need the space for other junk....
F
fizatjesus
I really like the light bar mounted on the front. Could you give us some info on how you mounted it there?
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
Welcome to the Club FIZ!!!
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
Nice post joey very well done!!
I was hesitant at first because it didn't seem very secure. It's mounted to the plastic only. I simply marked my holes and drilled the plastic. I used some large metal fender washers on the under side for support. So far it seems to be tough.
It holds up to this.....
1ac025c883db63005a65261462a704e1
F
fizatjesus
Right on, I believe that will be my next move.
