P1000m5 HondaSxS's Pioneer 1k, Build #2.
66,700
Removed rear seat belts as @joeymt33 mentioned to save weight. I never used them even once on my 2016.
Installed radio and antenna. Best place to mount as I dont have a roof. Looked at options behind my head on the cross members but decided here. View attachment 122844View attachment 122845View attachment 122846
Fyi if you got kids and don't give them rides that makes you a jtw! 5lbs don't matter what if you got to give people a ride offa mountain???
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
That will work - i’ll try and remember to bring my meter to TO and we can test it but your much better off there than having it right behind your head due to the radio waves it puts out. Plus you have a better grown plane up from on that bumper.
Reactions: Plumber32 and sharp
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
Anyone weigh one of the seats to see the weight savings
Reactions: sharp
63,963
Today I got 1 wear bar grinded on. Seems I cant find my paint. Tomorrow in will grind on the other side.
Skid plates partly installed. Need new hardware.
Decided not to do the middle supports at this time.
---> Universal Tube Reinforcement (Single)
A651545ec7ab9f8966d4d23f28210c85127743487ae118a652fe19b9cef032b5A7720c64806eb45694b6ae2080f289dfCeb715cb1bde9f16f370872f7c91d9306defe5de8e42117b153fcaf7b76a23ae
63,963
Custom switch panel and relay system is ready.
Drop in ready.
Hook to battery, plug into cig scoket. Done.
Awaiting 1 AUX rocker and a Radio rocker.
Using 4, 20a circuits. But I only used 3 here so I have a spare. Could free up one spot by eliminating USB or moving light bar to high beam trigger.
AUX will control- Key-on/off/on.
Winch only works when AUX is in Key-on mode.
Volte meter is hooked to AUX and reads which ever is selected. Key-on or battery. If I get a second battery it will read both by flipping AUX one way or other and moving the main power wires to the second battery.
Yes @Plumber32, @joeymt33 talked me into it.
Rear light is a worklight overide for auto backup lights. It is a grounded switch.
Ok.
Few more things to tidy up and she is ready to go in.
If you have a lot of money I can make you one too. Backpanel will be a little more organized for v2. E297acdce646faa0432d1f247aa3e41104f3b9bf6fa97bbb33a8e63f313a7c48C0bf4e9824932bfa7d3356d0f815b8d8
ToddACimer
ToddACimer
Pioneer 1005-2
3,564
14,633
Oshkosh, Wi
View attachment 123460View attachment 123461View attachment 123462View attachment 123463View attachment 123464
I'd have done center supports before the rock sliders. I do like how your sliders turned out. Id probably wrap mine more towards the edge and less underneath if I made a similar mod. Overall nice work!
Reactions: sharp and Plumber32
63,963
The bottom angle is flat on the bottom. The other angle is on the side. Hard to see but I like the location.
Chose sides because when I removed the trail armor from the 2016 and they had not rebent. Original bends were from factory skid plate and I pulled them down when i installed the skids.That was 2 years ago. Sides on my 2016 are beat to hell.
