P1000 Hot seat fixing
Rocket
Rocket
Rocket
283
946
Bullard, Texas
I’m trying this stuff out... so far it looks good, cuts easy (but is tuff as heck) and is cheap enough.... 2000 degrees resistant
It’s got metal fibers or something weaves into it....
6921F106 28BF 4D77 BBB1 81CFAC00576D AB72207A 7951 4128 8932 75E4E502102D 1EF6446B D34E 402E 9C52 BD3547435D5D
pct
pct
Lost in the hills
790
1,023
Letart WV
Welcome from WV Do you have the kit installed from honda it don't look like it would help but it will surprise you how much it helps and it is free which is rare with honda HaHa
Reactions: Rocket
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
I put a piece of the insulated pad in and it helped about half but I've still got a bilge fan I'm going to put in ,on a rocker switch so i can cool in summer and heat in winter. Thanks for info on factory fix wondering if it was any good
Sent from my SCH-R890 using Tapatalk
Reactions: pct
Rocket
Rocket
Rocket
283
946
Bullard, Texas
I’m going to get the SEAT CAMPAIGN done from Honda too... but that might take a while so in the meantime I have this fix ..
I think I will use both pieces
Reactions: pct and BWAF
BWAF
BWAF
8,864
42,478
Carthage MO
IT will definitely help. Keep us post on how much !!! :)
Reactions: pct and Rocket
Rocket
Rocket
Rocket
283
946
Bullard, Texas
We took her out for an hour or so ride tonight,, 41 degrees and about a e 35 degree wind chill.. we only had about 5% heat coming through (maybe 3%) from the seat ( the ONLY place heat came in was from the small cuts for seat belts).............. we could have used some of that HEAT tonight.. but we live in TEXAS so we have plenty of heat most of the time....
IMHO 100% FIXED (before Honda s Campaign)........
Reactions: BWAF
BWAF
BWAF
8,864
42,478
Carthage MO
Now just add a bilge fan on 6 pin two position rocker switch so you can reverse it in winter and blow air in floor board ive got mine wired but not in
Reactions: Rocket
BWAF
BWAF
8,864
42,478
Carthage MO
Sorry it was a 10 pin 30 ampD0bcba0c133ae82dfd25347f31c29111
