P1000 How fast do you ride your P1k on roads with stock tires
TexasJackKin
TexasJackKin
401
3,314
Dayton, NV
I've had my P1L-5 LE a bit over 60 a few times, but generally cruse around 45 or so. It gets noisy.....
Reactions: Lady01
E
Ericthered
Eric The Red
271
522
Sparks, NV
Because trails don't cross at best places we have to ride the highways from time to time here in Nevada. We haul ass in my 2017 1000-3 at about 55 on highway and when crossing salt beds it is best to go 60. I have factory tires.
Ridgeline21
Ridgeline21
5
23
Prosperity, SC
Stock size Tusk Terrabites (balanced) front and rear. 10 ply tires, DOT compliant street legal. 66 MPH all day long. Straight and smooth.
I did the same, saved the big horns for another day. Mostly below 50, still haven’t installed the turn signal kit to be really legal yet.
B939BC26 D067 4EAF BAD9 897CFFECE2DC
Vikes79
Vikes79
SKOL!
11,879
114,660
South Dakota
  2. Talon X4 LV
The question was "how fast you rode comfortably," not how fast you could push it dudes...
I drive the speed limit. Seriously.
In SD it’s 65 on the State roads, 55 on the county roads.
without the windshield the P1k5 can pull 65 no problem.
The black stones are noticeably quieter than the bighorns at speed.
G
Graybeard
AZ
Got pics? Would like to see that set up!
first ever post anyway since joining 10 months ago! Pics Or It Didn't Happen!
first ever post anyway since joining 10 months ago! Pics Or It Didn't Happen! 😂 🤣
The Spartans have a pretty standard tread. The material seems to wear very well though. I feel quite secure heading out into the Mojave with just the four of them. They are heavier than the OEMs but are basically a 12 ply tire. They also have an individual load capacity of 1250 lbs. per tire at 12 psi.
25B1F3D8 4524 4D7D 9FD3 90701F628CE9 2554C351 EDC3 4C83 B36F 6136DACE1C93 015A21D8 073C 433B B2D3 AE9EE9566CF7 8E4A2793 BCFE 4EFD 8D0B 6DD97DF77F5B
G
Graybeard
AZ
Sorry if this post is redundant, but I’m new to posting here. I believe I may have posted earlier that the Spartans have a pretty standard tread. The material seems to wear very well though. I feel quite secure heading out into the Mojave with just the four of them. They are heavier than the OEMs but are basically a 12 ply tire. They also have an individual load capacity of 1250 lbs. per tire at 12 psi.
C5C5C1E0 DF53 4588 8D88 139BFFF908DE 315EFE1A 0CF8 452A AECB E1FDE2119F02 DC625E04 5F43 4004 9629 2CBBD4B85229 E53616CC AF48 4313 B87F 72A55A2ED56B
L
Lloydtheredneck
80
418
53
Minnesota
22 in 5th gear and 27 -28 in 6th. slow cruise and enjoy whats around me. im here for the ride not going point a to b.
Robobrainiac
Robobrainiac
2,595
9,107
Oh stocks I've been matted just fine otherwise I'm doing the speed limit if not 5 over. I have 30" interco sniper 920s on my p1k-3 and have passed people on the highway with them on there. I also put balance beads in.
How do you like the interco sniper? Do they seem to last a while?
Reactions: ChadD and Smitty335
Scrappapotamus
The Scrappapotamus
794
4,288
Midway KY
  3. Talon X
  4. Talon R
  5. Talon R LV
My machine has the original Bighorns - have hit 66.
No half sends.
And no, the Bighorns aren't good pavement tires. My next tires are likely Kanati Mongrel 10-ply.
A lot of others say they are great on and off road. They are DOT compliant.
I have a '22 P1K-5 which has Mongrels and Elka shocks. I reside in the sticks where we have many country lanes that I travel often. I also have 2 Kubota Sidekicks wearing Mongrels which run 42 mph flat out. I run 50-55 mph in the Pioneer on the smaller roads and 60+ on state roads. They're good off road but not exceptional in clay mud, but amazing on tarmac and trails, especially the sandy soils we have south of here. They ride smooth, have strong side walls and aren't loud on pavement.
Pirata
Pirata
31
152
2nd Star to the Right
  1. 1000 6 Crew
Pedal to the metal on the country roads near our farm when needed however I usually keep it below 50 when traveling from area to area. Stock tires are fine but the thing to remember is like a big truck, bus, etc a utv is a drive straight, slam on the brakes and pray in the event of encountering an obstacle in the road at speed. Sharp turns with a high center of gravity is what you have to be aware of.
Scrappapotamus
The Scrappapotamus
794
4,288
Midway KY
  3. Talon X
  4. Talon R
  5. Talon R LV
As for noise and running at speed, my Pioneer this time of the year is tolerable. When I put my Honda door tops and soft cab enclosure on during the winter, the noise is maddening at speed. I attribute this to the straight cut gears in the tranny and the cavernous interior of the machine. I wear foam ear plugs when enclosing when it gets cold.
