P500 How long can BuzzBomber’s P520 stay stock?
Buzzbomber
17
128
NJ
Not long I guess.:) Picked it up two weeks ago.
AF7875DE DC59 4BE5 9266 6E27974CA966
Buncha boxes showed up today, so I dragged them into the garage.
Time to take inventory..
KyGal83
KyGal83
8,880
87,817
Kentucky
Packages!! 😍 Whatcha got? Whatcha got?? It’s rude to tease us with pics of packages! 😜… Tell us whatcha doing first? 🤤
Buzzbomber
17
128
NJ
So, somewhere in that mess of boxes is a KFI 66" poly blade snowplow setup, a 3,500lb KFI winch and KFI mount, accessory sub-harness, and the factory accessory 1-1/4" drawbar. May wind up going with the Moose 2" hitch later, but don't intend on towing/dragging anything too heavy at the moment.
Buzzbomber
17
128
NJ
Winch mount, plow mount, and wiring sub harness installed over the weekend. And I fabbed up a license plate mount.
That, soccer games for two of my kids, a niece’s birthday party, closing the pool, and splitting a couple cords of firewood made for a nice relaxing weekend. 😵‍💫
Buzzbomber
17
128
NJ
B9E89C73 4AD7 4A84 B0A0 B7692842E19B
finished up the winch install over the weekend.
30D5438A 82E9 4579 A63B 31D88B66C40B
got the plow blade put together
BE510C3D 6A8E 4118 9F99 E18968C38F7B
Made a bracket to mount the contactor block to the back of the frame crossmember.
Surface mounted the rocker switch to the bottom of the dash above the 12v socket and buttoned everything up for now after testing. Still need to decide if and where to mount the remote socket.
crewcabrob
crewcabrob
1,029
4,039
Omaha
I have the same winch (except mine is 4500#) installed by the dealer on my P520, and it's the same fairlead and winch line as Buzz's.
Interesting... I am not sure there is really a problem, but there has to be a reason everyone with a synthetic rope uses the hawse type and not the roller. Other than weight, the only other thing I can think of is burrs on the rollers catching the rope.
Anyone know why?
Looks good! Lots of fun goodies going on!
Reactions: Mudder and trigger
Buzzbomber
17
128
NJ
The roller fairlead was supplied with the winch. I am definitely no expert, but from what I've read the main reason hawse are preferred for synthetic is that if the rollers are worn with scratches, burrs, or sharp edges it will tear the rope fibers over time, as stated above by crewcabrob. I'm hoping it's not an issue with brand new rollers that have never seen cable. I guess if the gaps were large enough pinching could be an issue too.
crewcabrob
crewcabrob
1,029
4,039
Omaha
I wish my wife was able to see this and to hear that I might have something right...
Robobrainiac
Robobrainiac
2,550
8,957
Before I saw the picture I was going to say not for a second because the moment you sit in it you will be The Ultimate Mod.
Buzzbomber
17
128
NJ
Got the push tubes and plow blade mated up and adjusted over the weekend and hooked up the plow and tested everything out. So far, so good. Now we wait for the snow to fly.
In the meantime, thinking what the next accessory/mod will be. I'm thinking I need some storage for basic tools, a first aid kit, etc.
JCart
JCart
895
2,020
Kamloops, BC Canada.
BE23E805 FDB2 4C41 87F1 620DF16979BA
I’d recommended something like this if you plough lots. Saves the winch line from cutting into the spooled line on the drum. I leave this flat strap on year round as it protects the synthetic line from sun tends to keep mud and keerap off the spool.
