I know they are noisy engines...and...I've noticed a bit of noise from the top end from the start of ownership of the 500. Lately, It may have gotten slightly worse, so i did the valves last week during routine service.
So now I'm starting to concentrate on this noise...whereas i wasn't before, so its hard to say if it's really getting worse...or if i am getting worse.
Did the adjustment. Seemed no better. Got worked up to the point that saturday night, i did them in emergency surgery again by moonlight(shop light) just to ease my mind before riding, and they were spot on. You could use the +/- .1 mm aspect and go slightly tighter, i suppose, and maybe i will now that I'VE PULLED THE CYLINDER HEAD COVER OFF TO INSPECT. That's right.
When i fired it up today to unload and put in the shed, it seemed awfully loud...to the point where i said OK...had enough mystery...going to see what's going on.
So here's what's happening:
On cold starts, it taps fairly loud ( Most engines do make more noise cold...and the valvetrain IS splash fed on these). After maybe 30 seconds to a minute, it starts to quiet...but here's the thing; it will, at times, almost come in and out, kinda like a gunky hydro lifter. Once warm, its what i would consider loud-normal, like it always seems to have been, but if it stays at idle, you do get that in-and-out jingle tap at times. Stethoscope listening tells me the noise is loudest right over the intake rocker shaft.
Inspecting the rocker arms, they have NO play on the shaft, so there doesn't seem to be any wear there, and the pushrod tip/ball socket looks perfect. I really expected to find worn rockers, but they just aint. I may further disassemble this'll to be sure about the shafts.
Oil comes out of the cylinder galley after about 3 cranks at a decent rate (though it doesn't shoot by any means). The passages in the cover are clear. When running with the rear tappet nut cover off, oil readily splashes out.
FSM doesn't show a place to test oil pressure, but the looks of the top end say its OK.
I am familiar with the decompressor noise that some make, but as i said, this clearly originates from the intake side.
Again: Above idle, there is nothing but normal noise.
Sounds like this cold (not my video):
...and maybe a tiny bit, but much quieter when warm at idle. The guy in the video had the cam, oil pump, and other stuff replaced under warranty, to no avail.
My theory: The intake side is the last to get splash oil, and it just operates with barely enough at idle to stay good on my not-so-new- engine?
Anyone have the same noise?
TIA!
TIA!
