HBarlow
With my tire inflation pressure, that is.
I recently installed a set of four Tensor Regulator size 28x10x14 on Pioneer 1000 LE wheels. The tires are DOT approved 8 ply rated and pretty stiff. The P1K3 rides, drives, and handles well with the tires on dry pavement but it seems a little skittish on smooth wet blacktop.
Tire inflation pressure is around 21 psi and the tread surface looks flat to the naked eye but I'm not sure I have full tread contact with the road surface.
I'd like to try a little lower inflation pressure but don't want to risk a sudden deflation in a curve at 45 mph due to a tire bead losing it's seal on the rim. I don't do any trail riding or rock climbing so no worry about a rock breaking the bead seal.
These tires are probably molded with a hard rubber compound and never going to have the wet pavement grip of Michelins or other high quality highway tires so lower inflation pressure may not help.
What do the experienced owners recommend for inflation pressure?
