P1000 How often do you get flats
bumperm
bumperm
1,899
6,778
Gardnerville, NV
Plug kit and exterior sidewall patch kit. With the sidewall patch kit, it's gotta cure, so you'll have to cool your heels or introspectively reflect on your belly button for half an hour before hitting the trail again.
Robobrainiac
Robobrainiac
2,551
8,962
I carry a plug kit, a sidewall slug from the club store, a 12v cigarette plug compressor, small bottle of slime, a lighter, a can of brake cleaner, and a complete spare. I haven't had to use any of them yet on the pioneer. I keep all the items except for the spare in a backpack that comes along on any ride, 4 wheeler or pioneer. I have had a few beads pop off on the 4 wheelers that were all fixed using just the compressor. I had 1 flat on a 4 wheeler from the trail caused by a nail that was fixed on the trail using a plug then redone after getting home with a proper patch plug combo.
DDDonkey
I carry a plug kit and spare at camp. It I am going in a “long” ride and there is room I will carry a spare. I have had one side wall puncture, but I also run 8 or 10 ply tires on my rigs.
K
Kelldog
55
120
What kits are you carrying. Seems like amazon stuff would be in the cheap side. Emergencies to me not worth cheap. Looking at NAPA. CO2 cartrige better than 12 v compressor? Space is a premium also
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
E
Ericthered
Eric The Red
271
522
Sparks, NV
Factory tires on my 2017 1000-3. Have had a flat from stick in tread and one sidewall completely cut open by a bush. Both times I was off-trail, as none existed where I was going. Bought a set of same tires (4) and still running them. Made a rack for the spare and have had to get the use of it twice so far. Have 660 miles of desert trails and hills here in Northern Nevada. On a side note, I had the lower reverse installed. It does make a difference backing up hills. Worth every penny. Will probably save my clutch pack, so its a wash financially but a help on the trail. No break-downs to date. Change the oil and filters and run it.
rickoshea
i carry a plug kit and a viair compresser.i also put tireject in all 4 and so far no flats.i did have to pump up my right rear once from 5 psi so i guess the tireject did it's thing.i do need to get a sidewall slug tho'.
hibbert
65
81
CR
I have flatout in my stock tyres, run 95% forest trails, not had a flat in 3000km.
Also carry compressor, tyre repair kit and sidewall slug
P1K5Dave
P1K5Dave
2,245
8,426
Petoskey, MI
Those are pretty cool. Not cheap, but very nice.
