Howdy All! My first major issue on my 2018 1000-5 LE. Not sure if anyone is able to help out with this:
I went Hunting week before Last in normal operating conditions down in the hill country, actually probably never went over 15 mph. Weather was awesome, Dry conditions, no dogging the machine.
Everything worked like a charm, after loading up on Sunday in the enclosed trailer, I typically use the winch as a safety backup tie off with just a bit of tension, I turned the key on and spooled it out and hooked to the tie down eye in center. Of course I was busy with other things also and forgot to turn the key off. A few days later when I had time I was going to start it up and u load but battery was dead. I put the charger on it overnight and started it up next morning. As I drove across the yard to shop I noticed front wheels pulling the steering hard to the left. I stopped and then noticed the I-4WD light on. I shifted to turf but light continued to stay on, the pulling on front end stopped so apparently 4WD disengaged. I pulled the cables from battery thinking it might reset the issue but no luck. Checked all grounds I could think of and lights, fuses, wiring etc.
does anyone have any info or had this issue before. Any Ideas before I bring it in to shop and get hash tagged by Honda..?
Thanks in advance!
