P500 I need a horn and help installing it
GaryG
GaryG
58
40
KY
I need a horn to run off wildlife. We saw a bobcat yesterday and a huge bear print.
I was looking at this button
https://www.amazon.com/dp/B0197W7F2C/_encoding=UTF8?tag=sxsweb24-20
Or maybe this button since dash space is limited on the 500
https://www.amazon.com/dp/B015X34IP6/_encoding=UTF8?tag=sxsweb24-20
And this horn
https://www.amazon.com/dp/B01AUYK4EC/_encoding=UTF8?tag=sxsweb24-20
I’m not stuck on this horn or buttons I’m open to suggestions on those too.
I already have the accessory wiring harness it looked like some leads had two wires and some only had one wire.
Can I wire everything to the accessories Harness?
If not can I tie into the winch solenoid under the hood for the hot and get some kind or relay for the horn.
Any suggestions would be appreciated.
Gary
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
That switch and horn will work fine...i actually habe the same horn and its done well so far. No relay is needed for it..just a hot ground and an illumination . Personally i would use the small round button
Reactions: GaryG
GaryG
GaryG
58
40
KY
Did you use the accessory harness for the power and ground?
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
No..i have a 1000..but for that horn no relay os necessary. Just a hot and ground..if you have a dual lighted switch youll need a wire to power the top light be it headlight or key on power.
GaryG
GaryG
58
40
KY
so for Christmas I got the following items for my horn install. I need some help wiring it up.
I have the Accessory Harness so I want to use that to connect to the switch
I have a winch and I want to steal power from where the battery connects to the solenoid to power my horn. I do not want to run power all the way back to the battery again
From what I have read I think I am suppose to use the Yellow taped wire from the Accessory Harnas to connect to the switch.
Not sure if there are one or two wires in that bundle or not or what post they go to on the switch
I have a fuse holder I think I should connect it to the positive side of the solenoid where the "+" Connects. then connect the other end of the fuse holder to the relay. #30 pin
I Don't know much of anything else. Is this a Positive trigger setup or a Ground trigger setup.
where do all the other wires go?
Parts:
Switch
https://www.amazon.com/dp/B01G00GHQ4/_encoding=UTF8?tag=sxsweb24-20
Relay
https://www.amazon.com/dp/B01N66W2XF/_encoding=UTF8?tag=sxsweb24-20
Fuse Holder
https://www.amazon.com/dp/B017BAF7GS/_encoding=UTF8?tag=sxsweb24-20
Horn
Horn
GaryG
GaryG
58
40
KY
Is this the correct way to wire it?
Horn2
11,318
84,104
Mine did not need a relay and guessing your smaller horn will not. Just checked, one horn lead hot via button, second horn lead ground. Mounted bracket to an existing P500 bolt. Mine is a bit different looking horn. Only needed a relay on a bigger air compressor horn which was on my motorcycle. Good luck and welcome to forum.
35A9964F DFEC 48D1 ACBD F549E6D32ECF
GaryG
GaryG
58
40
KY
I was afraid to power the horn from the accessory Harness I though the harness only had enough power to trigger the relay and light the button up. I didn’t want to cook any factory wiring.
I appreciated all the help from this forum
Gary
11,318
84,104
Your horn only shows 1.5 amp. Honda OEM Harness description shows it can power all three accessories, horn, back up alarm, work light. Hope this helps simplify the installation.
A1BA629A 268A 444F BD87 E8C093BA2BB8
GaryG
GaryG
58
40
KY
Thank you that made it a lot simpler to install.
7552375ddf48256c16c989d064af81acD1332b114e9905a6fd62e9dfc3624fc1
I had a video of how it tooted , but I can’t figure out how to upload it.
rocmar
rocmar
4,741
5,773
4 CORNERS
And this horn
Gary
Dude..if you seen a bear print
...you need a gun...not a horn
....just sayin
Reactions: Mudwing and GaryG
GaryG
GaryG
58
40
KY
....just sayin
We always take a gun too. Bears are a nuisance around here. Ofcource we live in their front yard, I’m sure they don’t like us eathier.
Reactions: rocmar
rocmar
rocmar
4,741
5,773
4 CORNERS
Be Careful
...F-ckin bears are
sneaky..
I'm sure you know that..
Head on a swivel....
11,318
84,104
Would a 40 cal. Glock HP Take down a black bear, or make him mad?
bumperm
bumperm
1,848
6,646
Gardnerville, NV
Old thread.
A bear has have been stopped with a 9mm, but not many. Of course a 40 S&W is better than 9mm, and a 10mm is better still . . . staying with semi-autos and guns that'll still serve for concealed carry. The big revolvers, 454 Casull etc. are better, of course, but not exactly convenient for every day carry. The average bear charge is from about 25 yards and takes the bear 2 seconds to cover the distance. I think I'd rather have a Marlin Guide Gun in 45-70.
I live in black bear country on the eastern flank of the Sierra - - in an old apple orchard. The bears come down and get snockered on fermenting ground apples. They'll break into cars, we don't leave the keys in, no sense in risking having them DUI.
In the short vid, one comes by while I'm in the hot tub. Not shown is a P229 40 with suppressor and laser under the towel on the tub cover. I picked up the gun (not shown in video as I didn't want to upset PETA), the bear stopped and starred at me from 25 feet away. I put the laser back and forth on his eyes. He made the right decision (for both of us) and sauntered off up the mountain. Took awhile for the hairs on my neck to go back down.
