That was my next question, difference between 2 & 4 four pin switches. Answered!Here is how i did it;
Blue wires go to relays.
Red wires are the switched power (to turn on lights)
Yellow wires are power to light up the switch
Black wires are ground
See PDF diagram below.
View attachment 56519 View attachment 56520
Anything with a relay and lighted will be a 5,7, or 8 pin switch.That was my next question, difference between 2 & 4 four pin switches. Answered!
What about just lighted?Anything with a relay and lighted will be a 5,7, or 8 pin switch.
I'm going to be a friction genus when I get this figured out!What about just lighted?
I saw that and very nice wiring!?
These switches are only 4 pins
sounds like you have had one or two already lolI think I would need a rheostat fuse!
Iv'e got wiring on the brain right now! I can see a common ground buses bar or a and loop from one switch to the next with 4 post switches, and run one common ground to battery, but depending on the placement of the fuse panel, will need to run individual possitive wires to switches. And make a bundle out of them with some extras numbered? Hey my99svt am I on the right track?sounds like you have had one or two already lol
And make sure you run a few spare wires when you make your runs from front to behind the seat area. you never know when you'll want to add some thing down the road.Iv'e got wiring on the brain right now! I can see a common ground buses bar or a and loop from one switch to the next with 4 post switches, and run one common ground to battery, but depending on the placement of the fuse panel, will need to run individual possitive wires to switches. And make a bundle out of them with some extras numbered? Hey my99svt am I on the right track?
With the lighted switches how many pins you need on the switches and do they need to be wired into the head light?And make sure you run a few spare wires when you make your runs from front to behind the seat area. you never know when you'll want to add some thing down the road.
How do they wire? Do the 4 or 5 pin switches not have a common ground for all grounds, I understand looping the grounds together, don't under stand the 6 and 7 pins? Thanks!it depends on the switch you buy, the switches I bought have tw0 independant lites in them, the top one is wired to a 12v source controlled by the headlight switch. The lower light is wired so it comes on if the switch is turned on. Most of the switches I use are 6 or 7 pins spst or spdt switches.
What is the difference in the two switches?it depends on the switch you buy, the switches I bought have tw0 independant lites in them, the top one is wired to a 12v source controlled by the headlight switch. The lower light is wired so it comes on if the switch is turned on. Most of the switches I use are 6 or 7 pins spst or spdt switches.
6 pin is just an on/off switch with 2 independant lights (spst= single pole single throw)What is the difference in the two switches?
On your voltage meters, hot direct from batteries and ground from ignition switch?I got that, my next post is coming up.
NO! I may just switch them both, or do you guys have a better way?On your voltage meters, hot direct from batteries and ground from ignition switch?
