P1000 I need a wiring lesson or two!
208,730
I installed a battery and battery isolator and took the winch off the primary battery, got Whips coming, Have a fused box coming also, do I need a relay, don't think I do, the whips are Millar and come with converter and leads, needs toggle switch. Are relays only needed if your accessory doesn't come with it, told you I needed a lesson or two, HA
Reactions: Tramguage1
allgm1
allgm1
1,049
1,484
New Hampshire
if the item you are switching draws more current that the switch is rated for then you need a relay.
208,730
So I really don't understand what a relay does, let me give it a try, power up the relay from a fused source, come out of it to the accessory , toggle switch connects to relay and controls power to accessories? So any accessories that don't come with one you will need one?
208,730
Than the toggle switch is rated for?
RiverRat07
RiverRat07
Ridgeway
What your wiring is off?
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Acc that draw more amps than your switch can handle need a relay. A relay can handle more amps than your switch. Power from a batt of fuse box goes to your switch. From your switch it goes to one side of your relay and the other side of the relay goes to your acc.
RiverRat07
RiverRat07
Ridgeway
+ or -
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
The hot lead goes from power to switch to relay that way it closes the circuit
208,730
The fuse box is rated from 5 amps to 30 amps, that probably will cover most installs??????
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
Yes that should but whats your switch rated for usually 20 amps and a light bar is your big draw usually need to know tha amp draw on that
208,730
Do most light bars come with a relay?
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
Not that i have seen mine didnt i wired mine without a relay and my switch is messing up now i have to add a relay now to be safe
273,572
Uh no your idea of a relay is not correct.
A relay, allows you to use a low amp draw source to power several switches etc. From one source such as the black/white 15 amp accsy. wire. These switches when turned on should go to a high amp relay that has a direct power source from your secondary battery, the switch from the low amp power source when turned on energizes the relay to close providing power directly from battery with the amp draw allowed by size of relay from 20 amp small light bars up to 400 amp heavy duty winch relays.
Typically a power distribution module is the ticket. Much info here, including explanation of wiring the 8 post rocker switches correctly.
Start here and about the next 20 posts answering wiring questions.
P1000 - Jackal's P1000-5
Reactions: Amre2me2
