P500 Inexpensive wheels for turf tires
riderpilot
riderpilot
Southern VA
I am considering buying an inexpensive wheel and some turf tires to swap out for use around my property. I don't need a crazy amount of ground clearance so I am fine with stock size wheels or so. I intend to put something like these on them.
Carlisle Turf Master Turf Tires
Any help would be appreciated.
tomcj2
tomcj2
325
731
I recently spent a lot of time searching for wheels. The least expensive new wheels that I found were ITP Delta Steel Wheels. They are available at numerous places. The price varies greatly but $40 (usd) seems to be the normal low side.
Any tire will tear up your lawn if you make a tight turn. You may want to consider buying 14" wheels and inexpensive automotive tires.
riderpilot
riderpilot
Southern VA
I am not worried about a little tearing up, just want something less aggressive than my current tires. Also want to save the aggressive tread for where I actually need it.
I will look into the ITP Delta.
