Instrumentation Display failure
A
ajoynt
16
Just installed a power steering kit on my 2016 Pioneer 1000-3. When I performed a power up check and started the vehicle, the Instrument display was dead; no indications. I shut the vehicle off, disconnected the negative power to the battery and checked the fuses. No indication of blown fuse. Any suggestions on troubleshooting would be appreciated.
115,787
Welcome from the commie run state of Michigan.
how is your battery voltage?
if u disconnect the PS does it come back on?
Also need more info on your rig, miles hrs mods. Most important is pics of your rig. The issue at hand pics wouldnt hurt either! Also fix your location in your avitar from zip to state.
Pics Or It Didnt Happen!
DRZRon1
DRZRon1
1,209
3,901
PA
please post pics of your ride, first rule I learned was taught on here - Pics or It Didn't happen
did you check that you have +12V going to display? could be mis wired, bad connection, etc.
115,787
Thanks for all the inputs. Turned out to be a pulled pin in the display connector and I was able to repair it and it’s working perfectly.
Thats cool it wasnt the PS or something you did and got it fixed.
Now, do us a solid and post some pics of that ride eh?
