P1000 Is my Rearend exploding?
brock
brock
98
101
Arkansas
Does anyone else have a "pop" in the rearend when taking off from a stop? It has been doing this since my purchase on 10-27-2015. When i put it it high or low or reverse and start to accelerate POP. I tried to overlook it or get use to it but honestly its very annoying. When im in rough bouncy terrain at slow speeds (you know when its difficult to maintain steady pressure on the accelerator) its pop, pop, pop. When im driving and let up off of the gas pedal to to brake or turn or whatever then get back on the gas POP. It feels like slack in the driveline. Its also very jerky or touchy in rough rocky terrain at slow speeds. Have any of you guys had or heard this noise on yours? Please let me know as im trying to find out if its normal or time to take it to the dealer. Thanks
Donnie
Donnie
102
146
SW Missouri
Sorry, nope. Sounds like you may need to have the dealer look at it.
sthomp54
sthomp54
375
I think all the honda sxs have straight cut gears which have some play... many have used thicker oil to quiet things down. Mobile 1 75w140, its worth a shot if it is really bothering you.
Reactions: CumminsPusher
KevinSC
KevinSC
286
306
I wouldn't mess with it considering its still under warranty. I would be going to the dealer. I refuse to touch my machine under warranty except for oil change or putting on accessories, but no mine does not do that.
Springer
Springer
312
234
Could be going in and out of turf mode? Maybe the cable for the shifter is mis adjusted?
Reactions: pct
brock
brock
98
101
Arkansas
Im not sure on that. Mine seems to shift from turf, 2wd, 4wd, diff lock pretty good. 90% of the time its in turf mode on our farm i haven't noticed the rear axle being locked in turf mode and vise versa
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
With the tranny in neutral can you manually reach in and turn the drive shaft back and forth by hand? When I say turn, I mean just a little bit each way not a full revolution. It kind of sounds like there could be play in the driveline perhaps
Reactions: pct and Jody
hondabob
1,281
5,089
Prescott Valley, AZ
Compare it with another one to see if its normal. Its normal to hear a load click on easy accel as it shifts gears. It will shift into 6th gear at about 28 mph on easy accel.
Reactions: pct
brock
brock
98
101
Arkansas
Tflynn thanks i just tried that and yes i can twist the shaft a little and when i twist it back an forth i can here the knock in the rearend. I called the dealer and he said they all do it. The 500,700,1000. I said wow i sold my 700 for this 1000 but my 700 never did this. As usual theyre gonna play hard ball. Taking it to them monday. Lets see what happens
Reactions: pct
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
This weekend if I think of it I'll try mine and see if it does it too
ghost
ghost
993
1,873
BC
Mine has a little movement just enough to detect it. There's no knock - just a gentle tap when it engages.
The only thing that sounds anything like a pop on mine is the solenoid when it shifts.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
So when you move it, how far does it go? From lock to lock are we talking about a 1/16th of an inch? Less? More? Let's establish a standard for @brock to compare to.
brock
brock
98
101
Arkansas
I made a mark on the yoke and one on the rearend. It moves about 1/4". Also i noticed i can move the yoke side to side (not twist it side to side) but rather wiggle it left to right if you are facing the rear of the machine. On my truck there is a large nut on the yoke if it gets loose i can tighten it. I dont think thats the case here as i see no nut. I shot a stort video on my phone but cant seem to get it uploaded it says the file doesn't have an allowed extension. Country boy yes, computer smart no. Thank Tflynn for the help much appreciated
Reactions: Tflynn
ghost
ghost
993
1,873
BC
No - not 1/4.
Maybe 1/16 - if that.
I wasnt looking for side to side but it felt tight.
Reactions: Tflynn
brock
brock
98
101
Arkansas
No - not 1/4.
Thanks Ghost for checking yours. I feel like if everyone had this issue it would be all over the forum. Now if i can just get this video uploade
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
1/4" sounds like a lot to me. I'll check mine in a bit
pct
pct
Lost in the hills
790
1,023
Letart WV
I would contact your dealer it sounds like something in the locker it could be jumping out of turf mode of out of 2 wheel lock and could cause
damage to your rear end
Reactions: brock
