P500 Is there supposed to be a weld here??
208,013
2020 500. Just got it two weeks ago. Drivers side frame where the upper control arms bolts up looks like there is a weld missing?? The other side is welded all the way around. Drivers side is just barely welded on top of the tube leaving a huge open gap. How are y’alls??View attachment 232363
Is it bent also?
208,013
Thanks. Dealer is sending pics to Honda. We’ll see. I can this being a long process. Have about three miles on it 🤦🏻‍♂️🤦🏻‍♂️
I bet Honda issues a stop ride on your buggy? I wouldn't be surprised if they don't replace the frame?
BURNDOG
BURNDOG
84
229
Oregon
Mines welded both sides. I don’t see why it wouldn’t be. That certainly don’t look structurally sound.
Good luck with the dealer and Honda.
G
gtistiffler
I really don’t want a new frame. I don’t trust anyone to get it all back together as it was from the factory. In the perfect world I’d get a new unit. But doubt that’ll happen. Sad to say but wish I had forked the extra money for Can Am Trail 800
toddvdh
toddvdh
1,066
6,993
Green Bay, WI
Make sure you check the other side really good with a flashlight. You may have something more major wrong. It could be a shadow or dirt line, but that looks cracked to me.
Inked3E782DDC B390 4221 80BD 3CF548014424 LI
5,029
22,477
Dealer is coming to pick it up tomorrow. They are 2.5 hours away so good on them. Honda already said they want to swap the frame or send a welder. I don’t “want” either. We shall see.
I'd take a SKILLED welder l-o-o-o-o-o-o-o-n-g before I'd want a frame replacement. I just got my outfitted Talon back from the dealer and the craftsmanship is sadly lacking. :oops: I'd never trust anyone with a frame replacement, too many places for things to go wrong.
G
gtistiffler
agree. Thing has 11 miles on it. I really want a new unit. We shall see. I’m in no hurry. I’ll climb the ladder as high as I can.
There are good techs out there just saying....
I've replaced multiple frames including
4 seat Talon
3 seat Pioneer LE
CRF250L
TRX500FA
Kawasaki Prarie 650
I've also helped on a couple Goldwings
5,029
22,477
4 seat Talon
3 seat Pioneer LE
CRF250L
TRX500FA
Kawasaki Prarie 650
You aren't a part of the problem but there aren't many of you. I appreciate the knowledge you share with us here.
This is why I said what I did. I told the dealer that I'd do the snorkel since it's HondaBob's idea and I knew what needed to happen. They were trying to do the right thing but their tech has no idea what craftsmanship is. This is how it was delivered to me. he couldn't even copy the hole location from my wrecked Talon (stolen, wrecked, recovered, they're transferring the aftermarket to my new replacement).
I could have provided this photo but I thought I was doing the work.
I CMJfXgJ XL
This is what I got. When I did it, I carefully located the hole with a rasp bit in a electric drill because I didn't know exactly where the hole would end up, I cut it .010" at a time with constant trial fits. My fit was tight, the riser was almost a part of the fender, not flopping around in the breeze.
I sHZTx8W L
They couldn't even be bothered to notice the snorkel stood almost straight up, simply by spinning the curved riser 180*.
I k3vtmCB M
Done correctly. And why I'd have little faith in a frame replacement now.
I vVGqTf8 M
G
gtistiffler
Well after a week and a half they decided they want to.......give me the option of frame replacement or weld it. Told them I’m not happy with that and I want neither. Never should have left the factory this way. They made two mistakes, not welding it and QA not catching it and I will be the one taking the hit caused by their mistake. I’m not rolling over that easy. The saga continues.
