JayPo's 2024 Talon 1000R
Coeus
Coeus
Major General
70,162
662,334
Signal Mountain, TN
  2. Talon R4 LV
Right now I'm trying to heat the UMHW skid and bend it to the correct angle but it's stupid thick (1/2") so I don't know if it'll work. If this doesn't work then I'll probably just do what you suggested.
That’s what I had to do… I also used some clamps to hold it while it cooled
Homer
Homer
Happy Birthday MoPower!
1,242
16,024
GA
FWIW
I cut a tranverse line with skillsaw partially thru from the top where I wanted it to bend.
Multiple lines if it needs to curve.
Helped alot. Then used floorjack and board to flex plate up to drill and bolt.
JayPo
JayPo
Somewhat Well-Known Member
14,789
138,894
Tennessee
HMF front bumper installed. Way more difficult than expected as nothing lined up and you need to be some type of contortionist to get to parts. Also mounted the winch although I still need to do the wiring.
1000034641
Coeus
Coeus
Major General
70,162
662,334
Signal Mountain, TN
  2. Talon R4 LV
Did you have any welded nuts come loose when taking off factory? Nomo
EMAW
EMAW
Mama Tried!
3,465
43,822
Kansas
FWIW
Wait just a da,da,damn minute here……..Sounds like you might just need a build thread!!!! You got a secret?
JayPo
JayPo
14,789
138,894
Tennessee
SuperATV Flip-Up Windshield Installed. The Talon windshield flips up much higher than the one on Smokin' Jay, even after I modified Smokin' Jay's to gain another inch (nomo).
2024 07 13 160224
JayPo
JayPo
14,789
138,894
Tennessee
First rocker switch installed and it actually works! You'd think that because I'm like a computer genius and work with electronics every day that I would enjoy the wiring / electronics portion of the bolt on process. But no.
2024 07 14 151644
