P1000 Key on power
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
Where is the best place to get key-on power? All I need it for is to run the LED lights in the switch panel I have coming. I'm going to get the power to run whatever accessories from the battery.. or soon to be the second battery. This power is just to activate the lights in the switches and the back-lit script in the panel itself.
On the Yamaha, I got a simple in-line 4" long harness that plugged into the cig lighter and gave me a pig tail to hook to.
I don't imagine there is anything as simple as that for the Honda, is there?
Reactions: pioneerguy700
K9Paco
K9Paco
623
2,174
Lake Charles, La
  1. Talon X LV
I had to find out the hard way and tapped into the ones on the wrong side but tap into the white wire with the black stripe on the passenger side of the fuse box under the hood. It’s the acc wire and the 5th one down.
Reactions: mjn and Bad_bowtie
K9Paco
K9Paco
623
2,174
Lake Charles, La
  1. Talon X LV
This took me a week. Lol. With the winch also.
601189242779ff9d545311586c388d29
63,983
Reactions: mjn and JTW
I used a positap and found it easier to come off the cig/accessory wire down by the plug itself.
Neohio
Neohio
Beast of the East
13,414
65,751
Painesville Ohio
Holy crap people... I. Am. A. Dumbazz.
There's a freakin sticky about this!!
Forgive me. I'll attempt to look closer before I ask questions next time. o_O
You sir are forgiven. You are barely a month on our forum, wait until you decide to become a supporting member and unlock even more stuff! Like the pub!
mjn
mjn
1,409
5,206
Meh.. thanks, but I should know better. I've been admin on a huge regional motorcycle forum for years.. I'm supposed to know this sh!t.
207,989
I installed my isolator in the same location as yours, I water proofed the bottom and drilled several holes in the recess so it wouldn't hold water.,
