I'd say a world of difference better. Due to the fox shocks which you can add to any pioneer for about $1500How much better does an “LE” model ride and handle vs. a “base” model?
As what Polaris?? Just because it’s an LE or PK5 with Fox shocks doesn’t make it a sport machine..Would you say that an LE rides as plush as a Polaris? Will it handle well in fast winding trails? Carve corners?
Absolutely rides better than a ranger. Very plush at lower speeds. Still great and smooth at higher speeds. I think It handles well for what it is.Would you say that an LE rides as plush as a Polaris? Will it handle well in fast winding trails? Carve corners?
For a five seater it does really well. The Fox shocks make a HUGE difference but really any should. It’s not a sport machine and shouldn’t be thought of as such, it’s a people and load hauler that does everything well. The other limo 4-5 seaters would struggle over tough terrain that this doesn’t but on the dirt road would be gone. Till they break.Would you say that an LE rides as plush as a Polaris? Will it handle well in fast winding trails? Carve corners?
The question is, do you want i4wd or not.. the deluxe and LE are the same machine minus the 4wd system and Fox shocks.. the other stuff is just accessories. Brush guard, crappy Honda aluminum skid plate, under dash storage, and under seat storage (fancy garbage can).. the only other real difference is the painted body panels. Shocks can be had for $1400, the skid plate you should change anyway. The storage options can be had for $200. So the question is... do you want i4wd.Okay, I realize that even with the most refined shocks available, it’s still a big utility UTV. It’s never going to compete with an RZR in handling or ride. I’m just trying to get an idea if it’s worth the thousands of dollars extra for an LE.
Does the deluxe and le have the same led headlights? What's the price difference between deluxe and LE?
Or about 10 front axles..You get
Accessory Bumper
Skids/a-arm guards
Shocks
Painted panels
I-4WD.
-Hill start assist
I-4WD is about 1500-2000 if you remove the other adds.
