P1000 LED bar whining
sugarray
sugarray
Is this a game show?
661
1,257
WV
I installed a 42”, 240 watt Auxbeam light bar. When I flip the switch, it whines.
I have it hooked up using the factory wiring. It is grounded to the factory battery and the power pulled from 2nd battery at the + side of my fuse panel.
Thoughts?
Thoughts?
Downside to the cheap Amazon lightbars the electronics are NOISY.
I had one on my 700 that was like that, probably a loose connection somewhere on the board.
sugarray
sugarray
661
1,257
WV
@ohanacreek
So, what is not a "cheap Amazon lightbar"
sugarray
sugarray
661
1,257
WV
Yeah, prices for those are unreal and unreasonable. The technology isn't that new and not worth that. But, to each their own. It's like the iPhone X I guess, but I use my phone everyday for work so my return on investment is very high.
208,730
Eddies Baja designs on his new canam was $1800 *picks self up off floor from passing out*
Yea, but it's a very fast light!! I know from experience!
Reactions: JTW
322,675
The very high end units are better if you’re at 100 mph in the dunes or desert. Main differences are slightly better moisture protection and reflectors. Rigid reflectors will pump light out a little further and more focused but that’s just never a problem while trail riding, flood is always better then distance and if someone needs distance might as well go HID.
The cheaper units quite often overrate the lumans but can usually be figured out correctly base off of the fuse being used.
For those with deeper pockets or an absolute need for the best well... but for most of us as long as the lightbar has quality led burners (Cree Phillips Osram) they will work excellent for what we’re all trying to accomplish. Most of the mid and lower priced units are the same quality with different names.
We have been running heavy lighting for years and yet to have any noisy, dim, or actually fail however at 10% the cost for the cheaper bars a failure can be affordable and/or returned. Hell the lighting on our last few rigs alone would’ve ran upwards of 25-30k a peace as they were setup if Rigid lol.
Definitely not saying the heavy hitters are bad by any means here but to each their own for their own needs, that’s just my two cents.
