Lets talk Radios again... Pioneer takeover!
280,784
I can send you a file i have set up already... Chirp uses the old FRS and GMRS layout of frequencies and not the 2017 updates ones... so just be aware if you use theirs ... Basically in 2017 they combined them and some freq are the same.
I'll send you a DM for the file
Thanks for the .icf file for the channels.
210,944
Just want to call out that these are the new edition radios that lock out the FRS and GMRS Freq - meaning they will not transmit on those freq. - unless you unlock them... see the circled instructions below - I do not know if you have to do this every time the radio is turned on or if one time works going forward
See previous post for FRS frequency’s
The radio I bought as 15
I just bought a Rugged Radio RM60-V and I know spit about radios, been on the internet looking up radios for dummies, the sites just don't go low enough, need to find some sites for radio idiots. VHF and HF, what do most radios use, I just want to communication in the woods, VHF is basically line of site, ultra clear and HF uses skip transmission from what I understand? The radio I have has 15 channels to talk on and 2 that you only can listen to, do I need to send it off for programing or are the 15 channels enough for the trails? Thanks in advance!
Ragnar406
Ragnar406
The Great Bald One
4,460
17,082
Bella Vista, AR
First a RR should have come programmed
Reactions: Dp5hunter
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,607
Ridgeway, SC
Depending upon the radio it if VHF but could be UHF
nitzo
nitzo
521
1,106
East Coast, Florida
I'm with you @Smitty335, I got my radios from @Tramguage1 and don't have a clue what the hell I'm doing, tho he did get me great radios at a great price. I got them for the takeover thinking I'd get there and have lots of help, but we know what went on there.😞
Spektrum84
Spektrum84
50
132
Kansas
I'm still very new to radios. I've passed the amateur radio tech exam and have been studying for my general. From what I can tell the RM60-V is sold as a preprogrammed radio that doesn't require the operator to have a license to transmit. This is because the radio is programmed to use frequencies set by Rugged Radios and approved by the FCC. I think the license is attached to the device in this case. The frequencies they use are outside the amateur radio bands, so you wont be talking to anyone using a HAM radio that's operating it within the licensed limits. You'll only be able to hear and talk to other people using Rugged Radio products on the same channel.
OK, subbing to this. I do have a question for those using a TYT TH-8600: my radio, new, appears to be locked on 450 MHz and locked in memory mode. Pressing the V/M button doesn't switch from memory to VFO mode, but holding the V/M button will allow me to save a memory slot. So it's stuck in memory mode on 450MHz and I can't get it to VFO mode. I've seen instructions to unlock the range from 450-460 to the full amateur range. Does this unlock the VFO/MEM mode selection as well?
62,346
@Ragnar406 wasn't this what happened to mine at Mulberry and you were able to unlock and reprogram?
Ragnar406
Ragnar406
The Great Bald One
4,460
17,082
Bella Vista, AR
Yes
Yes @Spektrum84 if you will try two things
1. Look in the upper right hand corner of the screen and see if you see a key symbol - if so that means the LOCK is on the radio (key button lock) see below .
if that symbol is there: do the following
Press the third button down on the left side "F" then press the top button on the left side labeled "Lo / blue Key symbol" - this is the procedure to lock and unlock the keys of the radio and Mic
1597348089831
if that does not work or if the key symbol is not shown try the following:
To unlock make sure that the TH-8600 is turned off. Hold the "LO" (top left) button and the "A/B" (bottom right) button while turning the TH-8600 on.
Spektrum84
Spektrum84
50
132
Kansas
Yes
I don’t remember the lock symbol being on. I’ll check it when I get home. I think the unlock procedure you described is my best shot at getting it working.
elkaholic
elkaholic
2,097
8,607
Ridgeway, SC
It also can be a setting in the radio that you can only get to via a programming cable and programming software
Reactions: Spektrum84
Spektrum84
Spektrum84
50
132
Kansas
The box included the programming cable and a little software disc. Also seen there are some places to download the software, too. Sounds like I have a couple things I can try 👍 . The packaging box included a standard sheet of paper printout of the"hold these 2 buttons and then power on" instructions. Maybe that should have clued me in.
Reactions: Ragnar406
elkaholic
elkaholic
2,097
8,607
Ridgeway, SC
The box included the programming cable and a little software disc. Also seen there are some places to download the software, too. Sounds like I have a couple things I can try . The packaging box included a standard sheet of paper printout of the"hold these 2 buttons and then power on" instructions. Maybe that should have clued me in.
That three button start up routine actually unlocks the frequencies in the FRS and GMRS rangers of the radio. The FCC required TYT and a few other radio manufacturers to lock those frequencies out because the radios are not type rated for those frequencies by the FCC
Spektrum84
Spektrum84
50
132
Kansas
That's what I was thinking too. I don't have any intention of using frequencies outside the 2m/70cm amateur bands so that's why I hadn't tried it. But I guess it also unlocks my problem because it fixed my problem. V/M button now switches between modes and I can make adjustments like one would expect. I'll try the software sometime tonight and see what I can do with it.
Reactions: Mudder
