BOX1
Talon Light Bar
Bigblue1
77
92
NC
Tried to order the brackets and that asn number is no longer good...anyone have an updated number for the brackets?
Sent from my SM-G970U using Tapatalk
Try ASN# B07DNG5N2Q it looks like the same brackets.
Reactions: Eric37866
Jastoner
Jastoner
16
12
Arizona
Added a few lights.. and some green. Also fabricated an aluminum roof to streamline and shed some weight. Love it!
20191007 134625 20191014 154116 IMG 20191005 135440294
strubby
strubby
Central FL
Hey guys, neither Amazon links work any longer. Are the Polaris mounts in reference the same as the attached photo? I also see RokBlokz makes a similar set, but they're $70. Will the SATV flip up windshield clear a single row mounted with these brackets? Thanks!
Light Bar Mount
906UP
906UP
12,816
119,044
The 906
Added a 42" curved light bar today but still have to wire it up. Used curved brackets made specifically for a Polaris and drilled a hole in them and bolted it in with the same bolts that attaches the top of the windshield. The bar listed as a 42" but measures 43" and is the perfect fit and curved the same as the top. I just hope that the light quality will be ok.
Just wanted to say thanks for finding these, I just finished this up tonight.
Reactions: Glock21user
Bigblue1
77
92
NC
Good deal, I used mine a lot last weekend and it works great.
strubby
strubby
Central FL
I bought the RZR brackets, but they were an inch short of my light bar length (43.5") through bolting them to the frame brace and hung lower than I liked. Made some new brackets today out of stainless sheet I had on hand. Turned out ok I think. Need to paint them still.
20200120 125030
20200120 125051
20200120 125105
20200120 124433
Reactions: Glock21user and CID
906UP
906UP
12,816
119,044
The 906
Tommer
27
22
Minneapolis
These are the ones I ordered, says they're currently unavailable
I ordered the last bracket set available on amazon on Monday.
Also ordered the light bar below.
One of the reviews is a talon with it mounted and it looks pretty good. 54000 lumens is very bright and for the price ($106 for the wiring, light and mount) think it is a good option, but will see what the end result is this coming weekend.
https://www.amazon.com/gp/product/B071ZH34WQ/?tag=sxsweb24-20
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
  2. Talon x4
i’ve had good luck with the 22” and 32” that same style of light bar.
it’s no rigid but serviceable.
around 80’ range.
(Vs 900-1200’ with the rigid 20” hyperspot) :)
you are saving $700 though.........
Reactions: 906UP
Tommer
27
22
Minneapolis
around 80’ range.
For the price if it gets damaged or flakes out I can buy another in a year or two that will probably be better and cheaper. Swapping out the bar down the road after adding the wiring/mount shouldn't be a big deal.
Reactions: Sheetmetalfab
W
WideOpen201
10
Dequincy, LA
I've read that some had problems with the lightbar shaking at speed with the long brackets. So, I used tube clamps and the small stamped steel brackets that came with the 42" lightbar. Solid as a rock!
Front Light Bar
Light Bar Mounts
Mounted Light Bar
Bnorman
0
Wilkesboro
Yeah. I’m trying to find brackets and light bar to use with my oem glass windshield?
Glock21user
Glock21user
1,807
8,976
Livingston county, Mi.
Tommer
27
22
Minneapolis
I used these brackets with the oem windshield. Different holes need to be drilled, but that was easy. They also needed to be bent for the lightbar I used. I may modify it a bit more but it is pretty solid. I have repainted the bracket since the pictures were taken.
I am sure the similar brackets are the same.
Talon Bracket Talon Front
Tommer
27
22
Minneapolis
Oh and the light bar is crazy bright. Might modify the bracket to bring the bar a little closer to the roof line, but it kind of acts like a sunshade where it sits. All in all was about $110 for the bar, the brackets and the wiring. Well $125 with the filler so the light bar switch would be next to the light switch.
Code54
Code54
583
626
Hurricane West Virginia
Are you all noticing much glare or reflection off of the windshield when mounting it right below the roofline?
Glock21user
Glock21user
1,807
8,976
Due to the reflector design and being mounted in front of windshield you won't get any feedback.
The only time with an LED you will get a feedback of light is when the light lens gets covered with dust and dirt, the light will then bounce all over including down onto the hood and back into your vision.
We can always tell when the light bars on our Jeeps are filthy, other than poor light you will get a bounce back.
It sounds screwy but it is fact.
Reactions: Mudwing and 906UP
Bo_Darville
Bo_Darville
34
Cumming, GA
Which harness did you purchase for that light bar? I'm looking at that light bar as well and I'm glad it's working great for you.
BOX2
box3
