I already have a honda accessory subharness. I currently have my winch and rocker switch attached to the accessory subharness it and now want to install at light bar.
I just researched and see there are two harnessness I need to wire lights??
Aux Lights/Light Bar Wire Harness
Part #: 0SV31-HL5-201E
Accessory Sub Harness (already have)
08Z08-HL5-A00
Would I just cut the 2p white connector off the Aux Lights/Light Bar Wire Harness and attach that to the Red power wire from the LED Light bar and connect the ground (negative) to the the other wire??
Also, I would rather use honda accessory and light subharness so power comes on off with ignition. (prefer) vs using the wiring the harness, relay and fuse the light harness came with to direct wire to battery.
This two harness thing has now added confusion and I am now debating if its easier to just buy the aftermarket harness for lightbar itself vs trying to figure out if i need to spend the money to buy the additional honda light harness and what i need to do with honda harnessess to wire??
Please help! Here is the additional subharness from honda instructions. I already have the accessory subharness installed but not the honda light harness Aux/Light Wire Harness - 0SV31-HL5-201E - Instructions. -
I would seem to me after reading all and looking at the below honda diagram I can just buy a cheap switch and wires with connectors and make this honda harness myself and save $99??? I looks like the harness runs two seperate lights so I would just attach the light bar power to one of them and attache the light bar ground to the frame?? But I am not sure if the two wires below are + and negative?
Thanks!
08Z08-HL5-A00
Thanks!
