P1000 Looking for Throttle Max alternative
Dordon
Dordon
38
123
Eastern Kentucky
I have seen people using gate hinge to make the gas pedal easier on your foot fatigue. I have seen a video of someone making one but I can't seem to find it.
Reactions: GRANITE
bumperm
bumperm
1,849
6,648
Gardnerville, NV
I'm a DIY kinda guy too, weld, machine, invent mechanical stuff, and mostly willing to work my hind end off to save a nickel. In this case, just buy the darn thing. For being a "hinge" it's a very nice and well made hinge, hardly worth the effort to fab one in the shop IMO. :)
Reactions: CID and toddvdh
Wellzy
Wellzy
269
899
SW Wisconsin
2 x 10 board. I took this before it had been painted black. Changes the angle of your ankle and lets my short wife be able to reach the pedal with her heal on the board, rather than jabbing it with her toe which causes the lurching action.
Board
105,633
Did u use the search on here?
was pretty easy to find. Got to broaden your mind. That will work on a P1
156,863
castleman1
castleman1
12
73
think I'll try this too. Picked up 10'' hinge on amazon and will cut some off to have a wider contact point. Probably would have purchased throttle max if it was reasonably priced. ($50 max)
Reactions: Wellzy and Lady01
castleman1
castleman1
12
73
Turned out Pretty good with 10'' hinge. $10 hinge and couple screws/bolts and scrap metal piece. I would have offset it a little to the left if doing again to keep Hinge pin section from contacting sloped floor on right. 7'' hinge would have worked as well
PXL 20220517 205443278
PXL 20220517 205450586
PXL 20220517 205530245
PXL 20220517 192248726
Jas sxs
Jas sxs
137
525
rankin county ms
its easy to make and less than $20:00 (tractor Supply )with a rattle can of black paint i love it is a game changer just like the post above
Reactions: Lady01
N
Nvrgiveup
I used basically the same concept. I just had some scrap 2x4’s laying around and glued them together. It works like a charm. There’s a small piece of conveyor belt under mine to keep it from sliding around.
Wellzy
Wellzy
269
899
SW Wisconsin
I covered my bottom side with a piece of treadmill belt, it never moves. My buddy just ran a screw through his board and floor.
Bombardier Convert
Bombardier Convert
324
1,110
Minnesota USA
Just got done putting this one together in about 5 minutes with scrap 6" wide pine boards and 2 wood screws. It worked good for me first time out. I may tweak the design a bit but it's pretty much good as is. Seems to stay put and still easy to hit the brake as needed. Much easier on the ankle angle at least for me.
20220613 151028
Wellzy
Wellzy
269
899
SW Wisconsin
Give'r a coat of black rattle can deluxe and she's good to go!
Reactions: Bombardier Convert
N
Nvrgiveup
I did kinda the same thing with a couple 2x4,so glued together side by side, and put a small piece of conveyor belt under it to keep it from sliding. Mada world-famous difference!
