Loss of speedo
16Silverado
Saginaw MI
Hi I have a 19 talon R with about 600 miles on it and out of nowhere the speedo stopped working also each key cycle now after about a quarter mile of driving the power steering stops working I’m assuming it’s because it does not know how fast it’s going but it goes through all the gears and drives just fine minus power steering... anyone know what one of the speed sensors actually runs the speedo? Or what other problems may be going on thanks for the help
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
Check your battery connections and frame ground connection under the drivers seat.
16Silverado
Saginaw MI
Battery connections are good plus I cleaned up frame ground by engine plus one on the engine... I did not look for the one under the seat though thank you I will check that next
PaulF
PaulF
1,462
4,817
There are 6 speed sensors on the Talon, 4 on the front diff, 1 on the rear diff and 1 on the sub trans.
2 of them are for the DCT, 3 for the i4WD/ABS and the 6th speed sensor that signals the speedo and EPS is on the BACK right side of the front diff. Start by checking the plug and wiring here (marked in red)...
1621529130740
PaulF
PaulF
1,462
4,817
FYI, there have been reports of wires/connectors not fully inserted into plugs so check the plug carefully.
Reactions: Hometeam
16Silverado
Saginaw MI
Thank you very much you were 100% right I would have ended up spending hours looking all over the machine to find that you saved me lots of time
