P1000 Loud noise at 40mph. Cant figure it out
Blueline
illinois
hey guys, I have a question Im hoping someone can relate to. I just installed a set of fabric doors on my 2016 pioneer 1000. when i get to speeds around 40mph in it now it sounds literally like someone is running a circular saw. from what i can tell the noise is coming from the front of the machine somewhere. It has to be some type of vibration because it stops and start again based on your speeds, and doesn't matter if your on or off the throttle. My question is, has anyone had this similar noise and where the heck is it coming from? i cant seem to find it, and it never done it until the doors were installed.
Reactions: BWAF and sharp
That’s a weird noise for door material, did you misplace a tool near something rotating?
Are all the bolts tight?
There’s not much that should be able to make a noise like you described.
7,182
27,660
Is this machine new or older? also have you checked the subtrans oil level?
Reactions: sharp
Blueline
illinois
The machine is a 2016 with 3000 miles. All fluid levels are good. I just changed the oil tonight and checked everything. I will try to get a video for you all to hear and tell me what you think.
Need a video.. I chased a noise for 2 years before I finally found it a couple months ago.
Reactions: sharp
