P1000 Low gear gone
Hondoman
Hondoman
727
1,697
Texas
Mine wont stay in low, I'm guessing the gear dogs are worn. Starts out fine then bangs and goes into neutral. New shift cable and its properly adjusted. Sub trans fluid level fine.
I've called the three closest dealers to me and none have heard of this problem. One says they are a week out, but doesn't have room to take mine in now, the second one says bring it in and it will be 2-3 weeks (gut says it it be there much longer) and third says they are booked until july 15. I would attempt it myself, but I really dont have much room to work on it.
Has anyone replaced the gear(s) themselves and how hard was it. Has anyone had the dealer do it, and how much did it cost?
Thanks.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Sounds like its broken....I think the same thing happened to @Ragnar406
Reactions: Hondoman
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
Yes I have.
get a manual if you are mechanically inclined it is not hard at all.
Reactions: Hondoman
Hondoman
Hondoman
727
1,697
Texas
Yes I have.
Thanks. Yeah I can do it, just limited on space really.
Did you drain the oil then pull the sub tranny out from underneath? I'm assuming you have to pull it out to get to everything?
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
Yes it comes out the bottom I am not good at English I never got the hang of it, that's why I suggested a manual
Ok brief overview pull front bumper move front differential forward about a 1.5 inches the drive shaft is a floating spline up front, and got a clip holding in place by the sub trans, snap the shaft off, drain oil, disconnect sensors, and shift cable, unbolt, and remove.
2 of them are nut and work as guide studs.
Remove complete sub transmission it is not as hard as this list sounds, do NOT try splitting the case in the machine.
Hondoman
Hondoman
727
1,697
Texas
Awesome, thank you. Can you recommend a good manual?
Joel26
Port Allen Louisiana
My LOW gear is knocking and will not accelerate when I put my shift lever in “L”. I only had the bike for like 5 months maybe 6 I have 100 miles on it. Will Honda warranty this?
Reactions: Hondoman
Hondoman
Hondoman
727
1,697
Texas
Yours should be covered by the warranty. Mine is 3 years old.
Joel26
Ok.i have mud tires and a snorkel kit on it but I didn’t install it. The dealership sold it to me like that. Do you think the warranty will still cover it
Reactions: Hondoman
Hondoman
Hondoman
727
1,697
Texas
I dont see why not. Seems alot of machines left the showroom with misaligned shift cables which have caused these problems.
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
Here is a link to the post I started when I had pulled mine it will give you a idea what for gaskets and seal you will need if you replace them all.
Hondoman
Hondoman
727
1,697
Texas
Awesome, thank you! I wondered if there was a lower low gear I could use, guess not but the lower reverse would be nice.
I may do the igr at some point anyway.
Hondoman
Hondoman
727
1,697
Texas
@GPR1500SC is KILLING it!
How do you guys give a "love" icon, I can only do "like".
Reactions: GPR1500SC
Hondoman
Hondoman
727
1,697
Texas
Jumped in feet first. Ordered the parts to replace low and upgrading to the talon lower reverse.
20200531 153010
20200531 150754
20200531 150749
Ragnar406
Ragnar406
The Great Bald One
4,449
17,027
Bella Vista, AR
Reactions: Hondoman
Hondoman
Hondoman
727
1,697
Texas
Yep, that is how mine were worn when my low gear went out. I have a good dealer so they replaced in just over a week. really it took a week to get the parts in and they pulled repaired and replaced the day after parts came in. I had the extended warranty so it was covered by that ...
I wish I had a good dealer around here. Most have gone from Honda or Honda/Yamaha only to multi line dealers carrying Artic Cat, Polaris etc...
Service shops are now full of non-Hondas...
