P1000 Low Oil Pressure
O
Onefastdirtymax
7
Lawndale nc
Year
Miles
What's the story?
2016 with 1600 miles,had the clutch cover update and now after riding it for maybe 30 min and letting it idle a few seconds oil light comes on, have already replaced all O rings and also all split sealing rings in clutch housing and on main shaft,cleaned everything really good, swapped all 3 sensors, all new valves, 2 new clutch assembly's, new oil pumps, everything has completely been apart at least 5 times
Reactions: Buggyman and EMAW
HondaTech
Replaced the emergency valve?
Is the oil light accompanied by a code flashing on the dash?
O
Onefastdirtymax
7
Lawndale nc
No codes runs fine and shifts fine no clutch issues, has new emergency valve and spring
Reactions: Buggyman
HondaTech
The emergency valve was replaced after the clutch update cover was installed?
I'll look at some things tomorrow at work. There is a Wrench article about symptoms and causes after the clutch update has been performed.
O
Onefastdirtymax
7
Lawndale nc
Yes emergency valve was replaced after update cover along with everything else I had mentioned, all have been replaced after update trying to figure out what is causing the issue
HondaTech
Sorry here is the bulletin about possible issues after the update and possible causes.
  • ml.remaw52a.msm_17177_pioneer_clutch_repair_special_edition_1905 (1).pdf
Reactions: Buggyman
