P1000 Mid panel vs rear panel pioneer 1000-5
2018GMC
2018GMC
173
354
AZ
Hi all,
Just installed a super atv split windshield. I’ve noticed even with it cracked open, I still get dust swirling in from the back. Now it’s usually just me and a front passenger in the 1000-5 but I occasionally haul rear passengers.
Anyone have experience with the mid vs rear panel? I have been looking at the mid but then my rear passengers will be dusted.
If I just do the rear panel with a hard roof and windshield, will I still get dust coming in from the rear sides?
1000-5 fabric mid panel
0SR95-HL4-211A
1000-5 fabric rear panel
0SR95-HL4-211B
BVerhulst
BVerhulst
48
Colorado
Crap just order rear this morning
Don't be too discouraged; I have the SATV windshield and dust accumulation was significant, so I installed the rear panel. I can feel positive pressure throughout the cabin while driving since adding it. I haven't had an opportunity to test it on a dusty road yet, but I'm optimistic that there will be significant improvement.
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Thanks
Reactions: Lady01 and Isaiah
Boiler363
Boiler363
56
160
Hecker IL
Just joined the forum and noticed your post, I haven't had the chance to test much yet but I just put on a spidershade sun shade to use as a rear panel on my 1000-5. Was checking it out at the 4x4 shop and the guy said it's a bimini for a TJ. Anyhow, it's a little long but width is perfect for the cage, it's made out of very fine heavy duty mesh. Hoping it'll be enough to interrupt the dust swirl!
2018GMC
2018GMC
173
354
AZ
Ordered the mid panel.
Anyone running windshield + mid panel + rear panel?
2018GMC
2018GMC
173
354
AZ
Update ~ mid panel works great for keeping front seat dust free. I’ve noticed that There is a blast of air right behind your head.
Problem now is rear seat is getting all the dust.
I ordered the rear panel as well.
Going to try SATV split windshield, mid panel, rear panel.
Will update when I Go ride in dusty conditions again.
Dezrik
Dezrik
Follow me for adventure!
297
956
MOAB, Utahhhhhhhh
The back panel cuts some of the dust down but doesn't solve the problem. When driving anything faster then 35mph the dust still rolls in. We usually open up the window vents in the front to keep some of the dust out. We are thinking about buying the Aegis Air Spoiler or something similar to it.
20181202 134143
L
Lundude
14
12
Ut
Ok, new scenario, i have the JEI bed extender. If I put the rear soft panel on,do you guys think it will work, being that the tailgate will be down and the panel being a bit short then?
66,694
Yep. I've got the same setup. Zippers hold great.
BVerhulst
BVerhulst
48
Colorado
I have the split windshield with a Honda brand rear panel on my 1000-5. I haven't used it in terribly dusty conditions, but I can tell a remarkable improvement of positive air-pressure that eliminates exhaust odor just driving on paved roads in the neighborhood.
2018GMC
2018GMC
173
354
AZ
I run mid and rear panel. When I have rear passengers I open mid panel. The rear panel helps keep a lot of the dust behind the machine out. Not all by any means but rear doesn’t get nearly as dusty.
Seems like the best dust free experience is no front window no mid and rear is optional. Front window disturbs the positive airflow and creates a negative pressure that sucks dust in from sides and rear of machine. But it is needed in cool or wet weather!
I still am running no upper doors on front and rear. Just to much $$$ $600 for front OR rear?
Summers coming so can get by. May have to break down this coming winter and get doors.
G
grallison14
24
27
So I just purchased the OEM hard rear mid panel and doors. Does anyone know if one has to be installed before the other? I already installed the doors and it looks like I should have installed the rear panel first as it looks like the B-pillar door mounts are supposed to lay over top of the hard rear mid panel?
Reactions: Lady01
BrophyCreek
BrophyCreek
425
2,392
New Richmond, WI
Mid panel first. My mid panel stays on all the time. I take the hard doors off in the Spring and put the half doors back on
Reactions: Lady01 and TripleB
bridgermgmt
60
143
Tahoe
With your mid panel on, no hard doors, how well does it do with dust in the summer? I have a hard glass windshield and I am considering adding the mid panel but no full door.
Do you carry passengers with your mid panel still on? Any complaints on how that is?
107,236
A mid panel is pretty much the best thing you can do for dust in the summer. I have had one for quite a few years and has helped alot. Note, you will NEVER get rid of the dust! Its a SXS and way too many gaps to fill. During hunting season i have buddys that ride in the back with the mid panel up. They dont complain. Summer time..well they would most likely b**** cuz the mid panel stops most of the dust from the rear gets swirled around and trapped in the bed. Thats what your stopping with a mid panel. You can try just a rear panel when u have rear passengers to see if that helps
Reactions: Lady01
2018GMC
2018GMC
173
354
AZ
Fact is with any full windshield, even the SATV that tilts for a air gap you will get dust. If you don’t want dust in the cab you have to completely seal up cab with full doors and mid panel. Or from the showroom - stripper style, wide open, no windshield or panels.
I have the satv flip up windshield, mid and rear panel. Rear panel definitely stops some dust from getting in the rear but over 25mph you will get dust in the rear and front with a full windshield.
The fabric mid and rear panels have the option of rolling up for airflow or to talk with passengers in the rear. Overall they are ok but scratch very easily and zippers get stuck so rinse with water so they move freely again.
Reactions: Lady01
