P1000m5 Mirrors with soft doors and windshield ??
SP82
SP82
101
356
CA
I know this has been asked and I have looked at many posts and pics , I havent found and good fixes. So I have a p1000-5 with Honda 2 piece windshield and soft doors. Has anyone found a good mirror or alternative clamping spot on the front bars for side mirrors? Thanks in advanced. I know there’s someone here more creative than me. If that’s you please post pics.
Sent from my iPhone using Tapatalk Pro
DAV11
DAV11
105
194
Minnesota
Does the split windshield have a spot for a clamp similar to the full windshield?
20210907 081406
Happy trails
Happy trails
24
97
Peoria arizona
Yes, there is room for a mirror clamp with the honda signature 2 piece windshield. It is tight, but can be done. I just installed my windshield yesterday and got the mirrors to go back on. I too am interested in the original post and question. I intend to install fabric half doors and wonder what options there are for mirrors.
20210915 222450 20210915 222445 20210915 222430
SP82
SP82
101
356
CA
I figured it out.
All hail to the king.
Just kidding but I did get this to work.
D2b55e9abbf095d2f87798641a1740b0
958a5b7a39c779499376db5cc415c6dd
E304a29a0a9f38035fff3b386fd0196a
B9d5250f25be186001501d663b8ba548
These were cheap “”Kolpin” mirrors from Amazon. Like 45$ for the sides and rear view , I used there existing hardware (has to cut the bolts down like 1/2” ) and drilled a 3/8” hole in my plastic door skirts flipped the mirrors upside down and bolted them down. With doors installed I can see 100% of the driver mirror and about 85-90% of the passenger. The plastic door skirt was a little flimsy so i reinforced it at the top with some high tech wizardry.
I went for a perfectly legal trip around the block and could see great. They fold in flat for storage if your trailer is narrow and when there out the doors clear them perfectly. These mirrors are very light. I was going to use some lighted mirrors at one point but I think I’ll let that sit for now because there heavy and would probably crack the plastic over time. These mounted with a Allen bolt small metal washer on the inside and a rubber washer on the outside. Hope this helps.
DM me with details on where to send tips. $$.
sek-hunter
sek-hunter
306
572
@bdrescue, can you see the passenger side mirror well enough with the upper doors on? I need a set of these if so.
P
pappyo
593
2,377
Mirrors <>Soft Side Windows Closed <> Vision is Poor At Best.
Think OUT of the BOX.
Locate the Mirrors <> FORWARD <> to be seen through the Windshield
Takes a little imagination & fabrication ( CLEAR Vision is worth the Effort )
Attached pictures show this Done on Pioneer 500 <> 2nd. <> 3rd. & 5th. Pictures are form Setting IN the Seat.
2 <>Different methods shown <>1st 3 pictures<> using Roll Cage bolts <> 4th. & 5th. pictuers using Winhield Clamp bolts.
20210721 135817 20210721 135721 20210721 135714 20210908 125346 20210908 130355
Russ989
Russ989
22,560
146,470
I’m just give up my mirrors when I put my doors on for the winter. I may have to incorporate some of these ideas though.
W
wpugh0116
TN
HBarlow
HBarlow
1,618
6,009
Daniels, WV
Hi. I really Like this option. Can you explain to me better how you installed these and which mirrors you purchased?
See post #20 in this thread: P1000 - Mirrors
In my opinion, the search feature in this website software is not the most intuitive or user friendly I've seen but it is functional. If you search the forum for variations of "Honda Mirrors", "Honda Mirrors on Honda Soft Doors", you'll find a hundred or more posts on this subject. I know of no magic routes to finding the ones discussing the solution I used other than slogging through all of them.
As I have explained in earlier posts, I did not design or fabricate the brackets. A highly skilled metal fabricator friend made them for himself and generously gave me a set. His design is not patented and he has given me permission to post photos of his simple, clever, and very functional design. The fabricator does not object to anyone copying his design.
I can tell you the brackets work great. Mother Honda should copy and sell his design with their mirrors. Mine are OEM quality. They are strong and durable. The brackets do not vibrate, shake, or allow the mirrors to move.
GROR
GROR
58
240
Castle Dale, Utah
I designed a mirror/lightbar bracket for the Honda pioneer 1000 lineup. Its called the A-Pod HSD and is avaliable at ghost rocks off road.
20231003 073026 20231002 082702
O
Ozark Art
65079
Reactions: tjoreo
HBarlow
HBarlow
1,618
6,009
Daniels, WV
Did you buy the brackets or did you fab them yourself. Any info would be appreciated. Your installation looks great!!
A friend who is a skilled fabricator made a set for me. It's all covered in previous posts with photos and discussion. Search here in the forum.
Reactions: tjoreo
O
Ozark Art
65079
Will do and appreciate you getting back with me.
Reactions: tjoreo
