P1000 Missing screw
SeanKirk77
26
17
Or rather... Found screw and need some help getting it screwed in
I took my panels and hood off and got them rhino lined. Looks great!
But as I'm putting it all back together, I failed to remember that there is a hidden scre above the headlights on the inside. How did I get this screw out? Because I can see that it needs to go in but I can't figure out how.
Unless, it was the very last thing I did before totally removing the hood and therefore should have been the very first thing I should have done when putting it back on. It was all a PITA so I was hoping someone had a better suggestion other than "do it all over again"
66,870
lol...
Sorry to laugh but I remember what a PITA it was to even partly remove the front fenders.
I remember a handful of screws there that were super hard to access. Don't remember where they were but I do remember I don't want to do it again.
Murphy's laws says that if a guy takes something part there is always extra parts. hahah.
I'd just keep it until you take it apart again.
If you have extra parts, that just means that you're smarter than the engineer that put it together. You found a way to make it work with less parts!
Sent from my iPhone 10s
Reactions: Jediwrathchild
HondaTech
Removing the front fender is a breeze if you take everyting off together first. Bumper and all, then remove the parts after the fact. So much simpler.
